Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 12-08-2021, 12:32 PM
Nikita Nikita is offline
Default Automation Preview. Exclude Parameter
Dear Everyone,
I didn't find answer in the web, so may I ask it here?
If I click on Automation mode selector with CMD being in a Preview I can exclude a track out of it.
Is there any way to exclude just one parameter (send volume, eq band q, etc) from the Preview mode (revert to previous automation for particular param)?
Old 12-13-2021, 03:51 PM
reichman's Avatar
reichman reichman is offline
Default Re: Automation Preview. Exclude Parameter
I don't think that's possible. But what you can do is go to the Automation window and disable an automation type. For example, all Vol, or all Plug In, but that is global.
I have occasionally imported a track from sessions in the Session File Backups folder to recover automation I accidentally blew out in Preview.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 05-03-2022, 03:09 AM
kosmokrator kosmokrator is offline
I think I'd give my left hand for a 'preview except fader' function.
I want alle the time back that I wasted by having to recreate a delicate fader-ride only to realize I've been in preview all the time.
I'd be a younger man.
Old 05-03-2022, 08:25 AM
smurfyou smurfyou is offline
You and me both. I think my colleagues know when they hear the cursing.
~Will
Old 05-04-2022, 03:14 AM
I suggested an auto-preview mode 8 years ago. Slightly different than the original request but could save a ton of cursing ;-)
https://duc.avid.com/showpost.php?p=2183266&postcount=5
Old 05-05-2022, 02:24 PM
Yeah, good one as well.
Wouldn't be enough for me though, I often adjust stuff in preview while not having a selection.
I often tweak in preview, hit capture, make the selection and punch capture.
Actually, I almost always have preview on and all tracks in touch/latch without any exception.
That way I can always adjust anything, compare with preview suspend etc.
Old 05-05-2022, 02:54 PM
reichman's Avatar
While we're dreaming, here's the revision to Preview that I really need:
Optionally restrict Preview automation to selection only:
"While in Preview mode, Pro Tools would restrict playback of the changed automation parameters to the selection only. If no selection has been made, Preview would function the usual way. With a selection, the underlying automation would play during pre-roll, then switch to the Preview automation, and switch out during post-roll."
Nathaniel Reichman
Old 05-05-2022, 11:10 PM
yes, that would have the 'suspend preview'-softkey on the S6 not wear out as much, I agree.. :)
Copying automation to a different parameter Scott.Brownlee Pro Tools 2018 3 12-07-2020 04:46 PM
Copy automation to different parameter for same track SigFriedChicken Pro Tools 2018 3 07-01-2018 12:09 AM
Muting just one automation parameter? Scott G Post - Surround - Video 9 10-21-2016 12:44 PM
Glide automation to current parameter chavernac Pro Tools 9 0 05-14-2011 05:16 AM
anyway to access Preview and Automation preview on PC or Edit vudoo ProControl, Control|24, Command|8 1 09-12-2009 06:49 AM
