Old 09-30-2016, 02:05 AM
pdubber pdubber is offline
Default PT12.6 Bug With New Edit Window Fade Shaping Feature
In testing out the new feature that allows you to change a fade shape with the smart tool (or Cmd and selector tool), I have discovered a bug (or feature???).
When a fade is created using the fade dialog box we have three choices of shape - Standard, S-Curve, or a custom shape selected from a drop-down list.
If a fade is (or was previously) created with one of these custom shapes, the new reshaping features will not work. When clicking on the fade with the smart tool it will highlight yellow as expected, but you will not be able to change its shape at all.
This applies to fade ins, fade outs and crossfades on both PT 12.6 and PT HD 12.6. Make sure that your default fade settings in Preferences do not include any custom fade shapes. That's what was getting me. Once a fade is changed to Standard or S-Curve it will behave as expected.
Mac Mini 3.2 GHz 6-Core Intel Core i7, 64GB RAM
MacOS Monterey 12.7.1
Steinberg UR22 mkII
PT Ultimate 2023.9.0
Old 09-30-2016, 03:25 AM
midnightrambler midnightrambler is offline
Default Re: PT12.6 Bug With New Edit Window Fade Shaping Feature
Well, that's how the custom fades always behaved even in the "fades" dialogue window, so it shouldn't be that surprising.
Old 09-30-2016, 04:52 AM
Ah, good point. Somehow in 20+ years using Pro Tools I have never attempted to drag custom fade shapes in the fades dialogue window.
Still, I'm not sure the behaviour makes much sense for the edit window fade reshaping. If I'm clicking on it, it's because I want to change its shape - why should I be prevented from doing so?
At the very least, the Reference Guide section entitled Adjusting Fade Shapes with the Smart Tool in the Edit Window should be updated to mention that custom fade shapes will prevent the feature from working.
Steinberg UR22 mkII
Old 10-06-2016, 06:32 AM
The golfer The golfer is offline
I had the same problem but found your thread.
Thanks pdubber!
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
http://immersivesoundvr.com/
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
Midi edit window stuck to edit window lvsranch Pro Tools 11 7 04-04-2015 12:42 PM
Cannot change EDIT MODE in edit window Xavior Pro Tools M-Powered (Mac) 2 05-24-2007 12:51 AM
Feature Request Batch Fade In and Batch Fade Out mariang Pro Tools TDM Systems (Mac) 2 02-07-2007 01:32 AM
Fade Files 6.4... Pilot Error, Bug, or "Feature"? Resinsect 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-23-2004 10:12 AM
