Old 01-17-2011, 07:02 AM
koo_koo_bonkers koo_koo_bonkers is offline
Default Windows 7 Pro Tools 9 (not responding)
In windows 7 I have multiple applications open including PT9. When I switch away from PT9 for a few minutes the switch back, PT9 hangs with the application title bar showing (not responding) for about 10 seconds. Eventually after a few seconds PT9 starts working again. I'd just like to speed up my workflow so I'm looking for some tips to help correct this. Thanks !
MacPro 5,1 - 2 x 2.66 6 core - 32G Ram - SSD's - Mac OSX 10.12.6 - HD Native Card - Omni - Focusrite RedNet 5 - Avid Dock - iPad2
Old 01-17-2011, 10:46 AM
daeron80 daeron80 is offline
Default Re: Windows 7 Pro Tools 9 (not responding)
More RAM might do it. I get permanent freeze if I switch apps while bouncing, then try to cancel the bounce. Nothing to do but reboot.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 01-17-2011, 10:56 AM
cwsand's Avatar
cwsand cwsand is offline
Probably caused by the Aero theme - I went to a basic theme to avoid this. BTW - not really a good idea to run other apps during a bounce.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 01-17-2011, 02:31 PM
Thanks for the tip about Aero. I'll check into that. As long as a session is not taxing the system much, it's no problem running most programs in the background on a multi-core machine. At my day job, I often have sessions consisting of a single mono or stereo track with a couple light plugs on it bouncing down for 20-70 minutes. I can surf the web all I want meanwhile - that's most of my DUC time! And that's on a G5 PPC dual core running 7.3.1. Today I'm home on my much more powerful Win7 machine with 9.0.1, and I can't DUC during a bounce? Oy. Well, I can, but if I hear something that needs to be fixed, I can't cancel.
David J. Finnamore
Old 07-31-2011, 08:38 AM
q8test q8test is offline
Lightbulb Re: Windows 7 Pro Tools 9 (not responding)
hi there
i have the Same problem every time when i starting open the pro tools v 9 ;
it`s taKe mabye 1 TO 2 minute to open - and gives msg ( Not responding )
my motherbord in GIGABYTE INTEL(R) CORE(TM) I7 CPU 960 @3.20GHz
RAM 12 GB 64 OPERATION SYSTEM WIN7 SP1
SO I DONT I HAVE ANY PROBLEM WITH MY PC
PLZ NEED HELP >>
Old 07-31-2011, 03:32 PM
TOM@METRO's Avatar
Keeping clients happy is the main goal here. So that being the case, I never allow any online activity, any other open apps (other than ReWired), nor Windows Aero to exist while Pro Tools is running. These simple rules (along with all of the suggested optimizations) have kept PT as smooth as silk for us.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 07-31-2011, 05:11 PM
cwsand's Avatar
I have the same issue so I record my mix to a track. It's also nice because if you're 2-3 minutes into a mix and need to make a change at that point, you can make the adjustment and just resume the mix from there - crossfade and consolidate when you're done and export the region as a file.
BTW - just because I don't recommend running other apps while Pro Tools is running doesn't mean I don't do it!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 08-01-2011, 01:06 PM
Turning off Aero fixed it for me. Haven't had a lick of trouble since.
I usually mix to a track when going for the final mixes of a song or project. But probably 90% of my mixes are for reference or rehearsal - all that's needed is an mp3 to dropbox to people. In those cases, bounce saves a great deal of time and mouse clicks.
David J. Finnamore
Old 11-02-2011, 04:13 PM
Exclamation (not responding) - ( I dont think its will Fix in win 7 )
the pro tools Company Must make an update to Fix this Error
Cause it`s let us feel that Pro tools software Is Going Down For this Delay
or error in win 7 64 bit
So it`s is a opration System problem MEan a little confilecd between pro tools 9 or 10 the new one and With opration System >>>
Cause in Mac it`s more less than Windows
For info - i`m using a very good perfoumas Pc with 12 G Ram with gigabyte usb 3 x58
For all the Best
ALOMRAN-Studio
Old 11-02-2011, 08:14 PM
spenner spenner is offline
Default Re: (not responding) - ( I dont think its will Fix in win 7 )
For all the Best
Before typing with crayons, please consider that some of us are using iPads. That took up the entire screen.
Pro tools 8 le not responding abikambic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 04-13-2010 06:33 AM
Pro tools 8 le not responding abikambic General Discussion 1 04-11-2010 01:38 PM
Pro Tools NOT RESPONDING? advision205 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 20 03-15-2010 12:32 PM
LE not responding after Windows updates chainboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-19-2004 04:00 PM
Windows Media not responding vocalize 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-25-2004 03:18 PM
