  #21
Old 01-02-2014, 09:09 AM
clausiii's Avatar
clausiii clausiii is offline
Default Re: PT 11.1 Mix/Edit window toggle not working
It must be something with the (for me long awaited) feature to change the language in ProTools manualy.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
  #22
Old 01-02-2014, 11:08 AM
westberg westberg is offline
I'm experiencing the same problem.
  #23
Old 01-03-2014, 07:35 AM
VRW VRW is offline
Originally Posted by P_J View Post
If Window menu is already open, toggle works.
...actually I´m jealous as you are one step ahead...
here it does not work even when it´s open once. No way.
Just the blue light flashing 2 times at the menu, that´s it.
Already tried all the stuff (trashing prefs, changing language etc etc.)
Originally Posted by Kirby B. View Post
this must be a keyboard language set up thing. The folks mentioning the problem are from Austria and Norway.
+1
already thought that too as less other guys are reporting that issue.
Hopefully Avid is listening to it!
Cheers.
MacMini i7Quad, 16GB Ram, MacOS 10.9.1, Apogee Quartet, Genelec Active, Yamaha NS10, Pro Tools 11.1, Logic 10.0.5, Waves, MCDSP, Duende Native, Softube, HOFA, IK Multimedia etc.
  #24
Old 01-03-2014, 04:16 PM
steflechef steflechef is offline
I hav exactly the same issue. it is really not possible now to work fast on the mb pro !!!!! please avid fix that
  #25
Old 01-07-2014, 08:20 PM
JFrazier JFrazier is offline
pardon me in case i'm misreading this, but doesn't:
"command" + "~" work?
(as long as both mix/edit windows are open)
  #26
Old 01-07-2014, 10:33 PM
clausiii's Avatar
I have no "~" key. Where is it on your keyboard? Maybe mine is labeled different than yours...?
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
  #27
Old 01-08-2014, 12:59 AM
P_J P_J is offline
.. but doesn't: "command" + "~" work?
It doesn't work.
I use two keyboards, Apple wireless (no numpad) and for those numeric pad key commands I have normal keyboard connected. I still can toggle with normal keyboard using command + numeric pad '=', but with wireless kb toggle doesn't work anymore.
  #28
Old 01-08-2014, 02:36 AM
ha2dorff ha2dorff is offline
Norwegian keyboard:
On a keyboard with no numeric extension, the '=' button is on top of the '0' button. So to press '=' you have to press Shift '0'.
So I confirm that "Command + = " do not work on e.g. MacBook Pro.
English keyboard:
On a keyboard with no numeric extension, the '=' button is available without pressing Shift.
I guess the problem is for keyboard where you have to press Shift to reach '=' only.
  #29
Old 01-08-2014, 05:40 AM
it is the key to the LEFT of the number "1."
judging by pictures, it looks like you may have an "*" and "^."
my apologies if this has been proven not to work - just hoping to clarify.
  #30
Old 01-08-2014, 12:27 PM
VRW VRW is offline
Yep...it also does not on the Apple USB+numeric pad/Mac Mini Quad if you use CMD+"Shift"+0
as
It looks as though...
because
Woohoo! It definitely does work on using the "=" on the numeric pad!
As I had been using the bluetooth keyboard for years I just missed to try the "=" on my newly bought numeric pad keyboard.
Thanks a lot P_J for reminding me !
Best regards.
p.s.
as other folks don´t report this issue, this might be it.
Cheers!
Toggling plugin maps on d-command ? yellowshaman ICON & C|24 25 12-21-2012 12:48 PM
SHIFT COMMAND WHY germ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 12-12-2003 05:20 PM
Nudge vs Shift Command lcpellerin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-04-2001 01:53 PM
Can't "shift-command-B" sometimes... dans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-22-2000 11:38 AM
Losing [command][shift]B trombino Pro Tools TDM Systems (Mac) 12 07-12-2000 06:30 PM
