Old 07-24-2009, 12:17 PM
xxicjoy xxicjoy is offline
Default Aligning bar beat marker to specific timecode in 7.4
Is this doable. It takes me about 3 seconds to do this in Logic. I have been fumbling aroubnd in PT for about an hour now. I have video with a one second pre roll. I adjusted my session start to 00.59.59.00 then ballparked my tempo and found bar 3 and measured it to be 5 sec and 17 frames from the start so I backed up the session start by that amount. bar three is now about 1/4 frame off 1:00:00:00. I am trying wiggling the tempo at bar one but cant seem to dial it in. Any help?
Old 07-24-2009, 12:56 PM
emluper emluper is offline
Default Re: Aligning bar beat marker to specific timecode in 7.4
You might get a quicker answer for this in the Post forum. A 1/4 frame @ 30 fps is 8.34ms which is equal to about a 64th note at 112.4999 bpm. It might be better off for you to adjust the session back another 1/4 frame and get back to work. The math will drive you crazy and I don't know if any of the people you're doing the work for will be able to feel 1/4 frame. If that's not an option then you could be adjusting thousandths of a beat in the bpm value to get it to line up!
Old 07-24-2009, 01:42 PM
Thanks
I had success but way more complex than in logic. I ballparked via the session start time and then tweaked the start tempo till it lined up. I would freak out scoring a cartoon this way! FYI there is no subframe resolution in the session start offset. Thanks!
Old 07-24-2009, 02:08 PM
Yeah, that would make it a little difficult to slide it a 1/4 frame then wouldn't it!
Old 07-25-2009, 11:05 PM
jstaczek jstaczek is offline
If I understand your question:
- Set your session start to 00:59:59:00
- Move your cursor to 1:00:00:00
- Use Event | Identify Beat (cmd-I) and tell it that it's bar 1|1|000
Jason
Old 07-25-2009, 11:47 PM
Rail Jon Rogut Rail Jon Rogut is offline
Event->Time Operations->Move Song Start...
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Aligning Midi to Tempo Map with Beat Detective-Can't move analysis markers. Dizzi45Z Tips & Tricks 7 08-25-2015 02:35 PM
Trying to set bar/beat marker, tempo marker won't conform maitredebas Pro Tools M-Powered (Win) 0 07-31-2009 07:31 PM
Aligning a imported audio file to the beat gmorey Pro Tools M-Powered (Mac) 6 04-09-2009 10:12 AM
Aligning Rythm Tracks to Click Track (Beat Detective/Other) Mr_Johnny_D Tips & Tricks 1 07-06-2007 04:44 PM
Bar 1 at a specific timecode eljodon Pro Tools TDM Systems (Mac) 8 07-22-2002 12:26 AM
