Old 11-02-2001, 09:04 AM
Pako Pako is offline
Default Outboard S/PDIF Gear on the master fader!!!
Here's the deal. I have a TC M-One that I have hooked up on the S/PDIF. I have utilized many times using AUX or directly on a track.
Has anyone tried routing a outboard device (S/PDIF or Not) to the Master Fader? It just doesn't work. . . . . Maybe you can't do that with the 001, but it's a technique I use on my live gear on a regular basis.
[img]images/icons/confused.gif[/img]
|OS 10.2.8|80gb ATA100|120gb ATA100|
|Mac|FW800|DP 1.25ghz|1.5gb Ram|
|PTLE 6.1.2|Digi002r|Digimax|
|Recent PC to Mac convert|
Old 11-02-2001, 10:15 AM
KamaSutra77 KamaSutra77 is offline
Default Re: Outboard S/PDIF Gear on the master fader!!!
might be becase the master fader feeds the outputs directly, it the end of the line so to speak. So if you introduce, say a effect which includes delay inline with that output, also feed by the out-put you create a loop which quickly would degrade into digital mud.
Huh?
Old 11-02-2001, 10:25 PM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by KamaSutra77:
might be becase the master fader feeds the outputs directly, it the end of the line so to speak. So if you introduce, say a effect which includes delay inline with that output, also feed by the out-put you create a loop which quickly would degrade into digital mud.<HR></BLOCKQUOTE>
That's kind of what I was assuming, but wasn't able to find any leterature on it.
Thanks for confirming my suspicions.
Old 11-03-2001, 11:44 AM
ReniuR ReniuR is offline
you can change the master fader's input, I believe. So, if you can, in theory, you could rout your 1 and 2 outs (or spdf) to the device, and return it on 1 and 2.
I've been meaning to work with this more to save time with mastering.
-ReniuR
www.disposableproductions.com
Old 11-06-2001, 02:00 PM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by ReniuR:
<HR></BLOCKQUOTE>
I have tried this with no success. System lockup's every time. Please let me know if you get this to work.
~Cheers~
Old 11-07-2001, 05:07 PM
Digi9000000 Digi9000000 is offline
Why would you want to do this, as opposed to using an Aux? Just wondering... there is no advantage as far as I can tell.
Old 11-08-2001, 10:37 AM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Digi9000000:
Why would you want to do this, as opposed to using an Aux? Just wondering... there is no advantage as far as I can tell.<HR></BLOCKQUOTE>
A lot less routing. All tracks default to the master fader.
Old 11-08-2001, 11:42 AM
If you consider this notion: using spdif proccesing/input on an aux track=adjusting a track fader for playback mixing, a SPDIF insert on a track= you have to open a plugin paramater window to adjust levels.
Confusious say: Why cant I delay a delay?
Huh?
Old 11-08-2001, 11:49 AM
bassmac bassmac is offline
My M3000 is in the s/pdif in/out’s, and I can slap it on my master fader as a stereo insert no problem.
is it possible to use outboard gear? roblindsay ICON & C|24 2 07-31-2008 09:27 AM
Using outboard gear with 002 Laboratory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-29-2003 06:05 PM
Analog & S/PDIF out on 1 master fader on 002? LaJaZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 09-27-2003 01:17 PM
Who mixes in the box, but uses an outboard comp on the master fader? bassmac Pro Tools TDM Systems (Mac) 5 04-22-2003 02:49 AM
Outboard Gear as Insert On Master Fader dmunach 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-14-2003 12:51 AM
