Old 04-18-2013, 08:01 PM
garnoil garnoil is offline
Default How to export a plugin list
I am sending a mix to another studio and they asked me to send them a list of my plugins. Is there an easy way to do this (like an export plugin list command) or do I have to go to the plugin folder and copy and paste to a word document?
g
Old 04-18-2013, 08:26 PM
sunburst79 sunburst79 is offline
Default Re: How to export a plugin list
g
There used to be a generate plugin list function off the help menu in PT. I’m not sure its still in 10.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 04-18-2013, 11:01 PM
cjguitar cjguitar is offline
Select menu File>Export>Session Info as Text… and click check box "Include Plug-In List".
Chris M. Jacobson, CAS
Re-recording Mixer, Sound Designer
IMDB
Old 04-19-2013, 06:09 AM
Old 04-19-2013, 06:45 AM
quadraphonics quadraphonics is offline
There is a plug in/program called Plug Tools that can generate a CSV file with version info for every plug in you have on your system.
Randall
g
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 04-25-2013, 01:24 AM
tamasdragon tamasdragon is offline
And if you're not only want to export it, but would like to check if you're up-to-date, check out pluginupdate. It's a great utility.
my blog:Tamas Dragon
Old 11-24-2022, 03:37 AM
kosmokrator kosmokrator is offline
Hi there,
any solution to this in 2022?
The tools mentioned no longer seem to be around.
I can export a list of the plugin direcotry, that doesn't help much though, since f.e. all Waves Plugins 'hide' behind the WaveShell.
I need to send lists of installed plugins to contractors working for us.
@Avid, what's the solution for this?
Old 11-24-2022, 03:48 AM
JFreak's Avatar
JFreak JFreak is online now
Why wouldn't you try this? Courtesy of Darryl Ramm
Janne
Old 11-24-2022, 03:56 AM
Ben Jenssen's Avatar
Originally Posted by kosmokrator View Post
Hi there,
I use this:
PlugInfo: Audio Plugin Explorer
Very useful tool for checking installed plugins, versions etc. And you can select any and all plugins, right-click and select 'copy details', and paste into a word processor.
Unfortunately, Mac only, and it doesn't deal with the waveshell issue.
Price: $2.99.
Old 11-24-2022, 03:59 AM
Peter Gates PTPrefs. Scan plugins, select all, copy/paste into Numbers. Done.
HTML code is On
Pro Tools Export / Region List Issue drewsmith Pro Tools 10 0 03-09-2012 05:13 AM
Plugin list? Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-20-2010 08:03 AM
Print or Export Midi Event list tsoura 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-15-2008 08:35 AM
TL Space Plugin - Not in plugin list? joe.cavers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-31-2008 02:35 PM
LE with DVToolkit-no Export List!!??! MX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-25-2005 01:35 PM
