Old 06-19-2022, 10:09 AM
gthm's Avatar
gthm gthm is offline
Default No AAX version? No thanks.
I skip many interesting plugins because they are VST only.
I own Live but rarely use it to justify buying any VSTs.
Oh well.
Just a thought.
Pro Tools 2024.3
macOS 14.4
iMac (24-inch, M1, 2021)
(16GB RAM, 1TB SSD internal)
Samsung T7 x a few
Samsung 980 Pro x 2 (in Acasis TB/USB 4 enclosures)
Apogee Ensemble Thunderbolt (my hero)
Old 06-19-2022, 12:03 PM
BScout BScout is offline
Default Re: No AAX version? No thanks.
There are AAX wrappers for VST like Nugen's SigMod and Blue Cat.
Old 06-20-2022, 04:18 AM
Oh well.
Just a thought.
What plugins are you seeing that don't have an aax version?
Jack
QAPLA!
Old 06-30-2022, 11:27 AM
Oliver M Oliver M is offline
Oh well.
Just a thought.
In my opinion you made a big mistake in assuming that VST plug-ins are equally bad. I can well understand that you have concerns, because there are really a lot of bad VSTs out there but not everything is bad, I would say that many are very stable. I can assure you that your concerns are completely unfounded.
I work with Pro Tools and Ableton Live.
The AAX format alone doesn't make a plug-in better, it makes it a better option to work within the Pro Tools environment, cause AAX is the propriotary plug-in format for PT and thus is the first choice for PT.
I hope this helps.
Old 06-30-2022, 05:57 PM
Sardi Sardi is offline
I hope this helps.
I think you’ve totally misunderstood his issue.
He wants the plugins to be in AAX format so that he can use them in PT. He’s not implying that the VST format is bad.
Old 06-30-2022, 08:28 PM
sw rec sw rec is offline
I ran Universal Audio VST plugins as AAX-64 via Blue Cat Patchwork for a very long time, waiting for UA to make the AAX transformation. No issues at all, but one humorous side note, when I called UA to see if they had any reasons NOT to do it that way. “We don’t recommend ‘wrapping’ our plugins like this.” Which is funny, because when Pro Tools used RTAS plugins, UA plugins included a VST-to-RTAS wrapper.
Old 07-01-2022, 12:58 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
I also have skipped non AAX plugins due to Pro Tools being my main DAW. There's plenty of people making AAX stuff for it not to be a concern.
On the flip side, if a plugin is AAX only it has to be good to justify a purchase. In actuality, the AAX only plugins are generally more expensive so that also makes them harder to justify.
Ultimately, I'm pretty entrenched in Pro Tools but that might not always be the case. Plugins should really come in all he popular flavours, AAX, VST, AU to be serious players.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 07-01-2022, 02:09 AM
thin ice thin ice is offline
After years of add ons in an HD system, I am loving the simplicity of a Pro Tools native setup that just works every day. The last thing I want is wrappers, UAD or PCIe cards anymore.
It is aax only and Stephen said, there are many options for most plugins. It is only the odd thing like Melodyne that is unique and they do multi formats.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
Old 07-01-2022, 06:26 AM
LoudBassTone's Avatar
LoudBassTone LoudBassTone is offline
I echo the question, I am interested in what plugins you are seeing, that are interesting to you but not in AAX format? Are they EQ, compressor types or Virtual Instrument synths?
PT 2022.12 studio, Cubase 12 Pro, 12 Core Mac Pro 6,1 96GB OS X 12.6.6, Mac Mini i7 QC 16GB, Digico Soundgrid DLI, Revive Audio 96IO & 192 DBox & 2BussLT for summing, Waves, SoundToys and a pile of other plugins. NI Maschine/Komplete Ultimate 12 and many many, too many Kontakt Libraries.
https://www.youtube.com/channel/UCmT..._as=subscriber
HTML code is On
Eventide updates: Anthology X version 1.0.20 & Blackhole Native version 2.2.6 unkJE AAX Plug-ins 8 04-12-2017 04:57 PM
Avid Nexis : différence entre la version pro et la version initiale Gustavo Woltmann Le Forum en Français 2 01-18-2017 09:37 AM
Reason: Incompatible library version: Pro Tools requires version 9.0.6 or later, but Patrick H macOS 3 11-20-2012 02:46 PM
HELP! PT10 Opening new version session in older version Claudiu Pro Tools 10 6 11-04-2012 03:32 PM
Incompatible library version: CFnd provides version 7.2.0 heshion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-24-2009 03:42 PM
