Old 05-14-2022, 08:09 AM
sleiweke sleiweke is offline
Default AAE error -20026
So what's this AAE error -20026 all about? I get it when opening a session from time to time. I couldn't find it on Avid's list of errors and descriptions.
sleiweke
2019 Mac Pro Rack 3.3 GHz 12-Core 96 GB RAM
OS12.6.3
HDX Pro Tools 2023.6
Lynx Aurora (n) 32
2 Avid S1's
Old 05-14-2022, 11:10 AM
sw rec sw rec is online now
Default Re: AAE error -20026
You realize, of course, we’re totally shooting in the dark when you provide zero system info.
When I Googled it, I found this:
“It’s an iZotope RX error – usually happens when you have saved the session with the iZotope window open. It is safe to ignore and I believe iZotope is aware of the issue.”
Old 09-17-2022, 07:40 AM
relse relse is offline
The error msg I get reads "Pro Tools was unable to Auto Backup your session" (then some other stuff, then:) Error was -20026.
I don't use Izotope RX withing Pro Tools.
But I just upgraded from Izotope Ozone 9 to Izotope Ozone 10, which I do use as a plug-in withing Pro Tools, and I started getting this error whenever PT tried to auto-backup my session. I never had the problem with Ozone 9.
And when I tried to save the session, I got the error message "Could not save '' because (-20026) while saving tracks."
The issue is definitely Izotope related.
Until reading this post, I did not relate it to having the Izotope window open. I will test some more, and report the issue to Izotope if it persists.
Robert
(Pro Tools 2021.10.0, Windows 10 Professional)
Old 09-17-2022, 08:24 AM
Sometimes plugins can cause problems just by being installed, but not used in any session. Simple test: move a suspected plugin out of the Plugins folder and test
Old 09-17-2022, 09:01 AM
See this thread, especically the last few posts.
https://duc.avid.com/showthread.php?t=421579
Looks like a known Izotope 10 save issue.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 09-17-2022, 09:25 AM
The Weed's Avatar
The Weed The Weed is offline
I have Izotope RX Standard 10 and have no trouble saving with or without a plug-in window open. Latest Windows 10, PT 2022.7.105 I don't use Auto-Save.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 11-16-2022, 03:05 PM
Blake Henderson Blake Henderson is offline
I'm having this issue. Using an M1 Mac with latest versions of all softwares and Mac 12.6.1
Any word from Izotope about a fix? It's a bummer.
Clumsy Congregation
AAE Error 20026 was encountered. henningaround macOS 7 05-23-2019 12:34 AM
AAE Error -20026 ulisauer Windows 1 02-21-2018 07:12 AM
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error EricMulhern macOS 1 11-20-2011 05:39 PM
Error type 10,address error ,illegal error, buss error ,illegal instruction KasticK Pro Tools TDM Systems (Mac) 3 05-14-2003 11:21 AM
Buss error,Address error,ilegal instruction,error type 10 KasticK Pro Tools TDM Systems (Mac) 1 02-08-2003 05:49 PM
