Need help formatting dedicated audio drive
I'm running Windows XP Pro. I have everything on an IBM Deskstar 60GB GPX and I only have been using about half of it to be honest. I recently acquired a new Maxtor 40GB hard drive that I've been using recently as a backup for my 60GB. I had the idea that I wanted to:
1)Format the 40GB & use it as my new system disk 2)Back up precious data from my 60GB onto the 40GB (new system disk) 3)And then format my 60GB and use it as a dedicated audio drive for my Digi 002 Well windows won't let me format, or even partition my 40GB. I think it has somethign to do with the paging file. Windows keeps saying that I cannot format because the disk contains a paging file. The only thing is, I can't seem to remedy the situation. I took a screen shot you can view here. Any ideas? I've looked up just about every single query string on google & windows help, but still nothing of use. Disk Management Screenshot
Digi 002 Dual 2.0 G5 |
Re: Need help formatting dedicated audio drive
Shouldn't you use the Maxtor MaxBlast software to format and partition your drive.. it don't care about any stinking paging files.
Rail
MaxBlast installs itself onto a floppy disk in your A: drive & then you go on from there. But that's not an option for me
Right click on My Computer and select Properties and then the Advanced tab and push the button for "Performance Settings" and then the Advanced tab. Then push the "Virtual Memory" Change button.
Select the drive (F) that you want to format and change the setting to "No paging file" push the Set button and then OK your way out and restart. Try to format the drive. Rail
...and before you close out that window, select the C drive and set it to have a paging file, if there isn't one set for that drive yet...
Windows wants to have a paging file someplace. |
i love my apple iPhone! |
You'll need to use the Maxtor utility I think... buy a floppy drive for the $10 they probably cost.
Rail
Why dont you just install windows on the new 40gig...then use the 60 as a slave. Copy the things you want then reformat the 60 if nessecary...
Rail
dedicated audio drive? | fubanger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-01-2007 09:33 PM |
New dedicated audio drive | (BANGAH) | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-14-2003 01:01 AM |
Dedicated audio drive and jumpers | Jay_Mora | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-30-2001 04:35 AM |
Hard Drive Performance Dual Processors and Dedicated Audio Drive | j_jayzatuc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-03-2000 05:52 PM |
Dedicated audio 20 GB ATA Drive with 001? | tombi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 04-26-2000 04:06 PM |
