Old 01-02-2011, 10:35 AM
daddycrash daddycrash is offline
Default Registration not appeared on Avid Account
I registered my Mbox2 mini back in Jan '10 and received the confirmation email . However Pro tools 8 Le does not appear in " My Products" and as the windows side of the installer disc is corrupt ( used mac until now) i cannot re download an installer .
Any ideas anyone
dc
Old 01-02-2011, 10:46 AM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: Registration not appeared on Avid Account
Check your email.
Administrator
Old 01-02-2011, 11:15 AM
Thank you, i will download it now , i want to install it on Win 7 Pro 64bit , should there be any problem ? Also , would it be possible to get my LE system registered into my Avid account , my PT 8 HD is in there and i did them both around the same time.I tried to reregister but i was told the system was already registered , i can supply a copy of the registration response from digi if someone gives me an email address
regards
DC
Old 01-02-2011, 02:16 PM
Avid's Avatar
Administrator
You are registered already for "Mbox 2 Mini w/8", meaning that the Pro Tools LE 8 installation DVD was included with the purchase. So that is why there is no download of 8 in your avid account. You have the registration confirmation email, and customer support has the registration in their database.
As far as installation, you would want to follow the instructions here:
Pro Tools LE 8.0.4 Update for Windows
Installation Instructions
The download on this page is an updater. You must have Pro Tools LE 8.0, 8.0.1 or 8.0.3 (or any CS releases for those versions) already installed on your computer to use this updater.
1. Download the Pro Tools 8.0.4 Updater from this page
2. Verify that Pro Tools 8.0-8.0.3 is already installed on your system
3. Launch the Pro Tools 8.0.4 Updater and follow onscreen instructions
Windows 7 Additional Installation Instructions
Caution: When installing a version prior to Pro Tools 8.0.4 on a Windows 7 machine, DO NOT plug in your LE device when the installer instructs you to do so. This could cause installation errors. Users should install Pro Tools LE 8.0.x without their device plugged in, then use the 8.0.4 updater and follow onscreen instructions, plugging in their LE peripheral when instructed.
Download the Pro Tools LE 8.0.4 Updater, install the Pro Tools LE 8.0.3 full installer that you were sent without launching Pro Tools 8.0.3, then update to 8.0.4 following those instructions.
Administrator
Old 01-02-2011, 03:17 PM
Thanks for the speedy reply . However , there appears to be nothing in my avid account that shows the system , may i suggest the registration information is shown under "your products" so the user can retrieve serial numbers etc and additional downloads such as dvtoolkit 2 . The installer on the dvd quite clearly states:
"If you have purchased and activated DV Toolkit 2
and wish to download a copy of the installer,
you will find a link for this in your My Digi account."
just a thought
paul
Possible to delete registration from Avid Master Account? mufasis Getting Started 0 09-09-2013 07:09 PM
Help - Can't find my HD3 card registration on my account. karljohnson Pro Tools TDM Systems (Mac) 2 10-23-2011 11:52 AM
Avid admin,Where are you???PT LE 8 registration and avid login not jiving??? jacobsapple 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-03-2011 10:40 AM
My registration does not appeared on Avid Account mickc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-03-2011 09:58 AM
Can't seem to match PT8 LE registration with Avid Account TimDogg General Discussion 1 02-17-2011 06:52 PM
