Old 11-09-2010, 07:30 PM
Snafu Snafu is offline
Default Very Odd Issue With Playback
Hello peeps,
having a very unusual problem- playback as stopped after working fine for about 5 years!! Recording still works, the waves are all still there, I can even hear the audio I record in while recording..but then I press play, the master levels appear normal (visually) but no audio comes out whatsoever!! Cables and Amp not the problem either, I think it's the first time I'm stuck for options here!!
Any ideas/help would be greatly appreciated...
PS: No mutes are on either, and the mix buknob is turned to the right..Still must be something obvious, everyhting was working til yesterday. It's an old 6.4cs9 on Mbox1:)
Old 11-09-2010, 10:18 PM
tonepad tonepad is offline
Default Re: Very Odd Issue With Playback
have you tried the headphone out of the MB?
My day job:
Wilson Dyer MPSE
Sound Supervisor: NCIS Los Angeles, CBS Television
Old 11-10-2010, 01:15 AM
Thanks for the reply Tonepad. I hadn't actually tried it, but nothing outputs from there either (unless again you have record enabled and playing through an external source).
Old 11-10-2010, 11:02 AM
Sorry to bump this, but 2nd day now with no playback and work is pushing!! DigiTechSupport, no ideas?? Did a thorough search through the forum and all I could see is issues from folk not knowing how to use the mix knob:)
Thanks again in advance!
Old 11-10-2010, 06:17 PM
The Weed's Avatar
The Weed The Weed is offline
Are you in Input Only monitoring?
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 11-11-2010, 12:28 AM
No, auto-input. Tried switching it in case it helped, but nada. I'm really struggling to see what's happening here, when I read your post I thought it must be something like that, as the problem came out of nowhere. If the box itself was faulty I doubt it would play out when recording.
Thanks for giving it a shot.
Old 11-11-2010, 06:10 PM
I'm getting no help from Digi on this, so will try posting more details...I didn't initially as the setup hads worked for years, but here goes...
PROBLEM: No sound on playback. Bouncing still works!!!! (you don't hear it, but can play it from windown media player etc)
AMD Athlon 3200
1GB RAM
Windows XP
PT 6.4cs9
2 300GB Sata Drives
Tried everything in Troubleshooting guides...
Tried uninstall and reinstall
Tried replacing cables, amp channel etc
Not the position of the mix knob causing this!
No sound off headphones either
I'm desperate for help, was about to send an LP that was 5 years in the making to the pressing plant so if anyone can help it would be extremely appreciated
Thanks again
Old 11-11-2010, 07:53 PM
cwsand's Avatar
cwsand cwsand is offline
If you can, try installing PT on another pc and see if the MBox works there.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 11-11-2010, 08:20 PM
I'm hoping to try that soon, but unable to do so at least until Monday, and then I don't know if that PC will be PT compatible. Also know no one with an Mbox to try a diferent box on my PC. I've even lost my registration number and can't contact Avid support...
Thanks for your time cwsans!
Old 11-12-2010, 03:57 AM
OK, after trying everything, I thought let's go old school. I unplugged and it plugged it back in (USB). Well it did what the reinstall couldn't, and I'm back in business. Just thought this may be somehitng that should go in the general troubeshooting, I had actually started looking at prices for a new mbox and once I got my hands on somebody else's and saw that it worked and mine doesn't I might have replaced a perfectly working mbox...
Thanks again to everybody who tried to help out.
PT 10 playback issue Mac OS X JRodriguez2109 macOS 6 03-13-2012 11:31 PM
playback issue beatbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-12-2009 04:49 PM
re- playback issue jaws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-12-2008 12:48 PM
Playback Issue vsideproductions Tips & Tricks 1 08-05-2006 07:19 PM
6.7 amd DVD playback issue? Armando Pro Tools TDM Systems (Mac) 1 11-05-2004 02:02 PM
