  #7071
Old 02-21-2023, 02:44 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Re: i7 Builds - Specs and Results
Originally Posted by Skwaidu View Post
Ok, FYI Samsung's RAPID mode is just a RAM cache, basically - so your most often accessed samples are getting cached into system RAM and it feels fast, but for any samples that don't get that treatment (rarely used?) it's just as slow as SATA normally, from what I gather. Many folks swear by PCIe 4 drives for samples (OTOH for audio IMHO even PCIe 3 is fast enough, even for truly massive track counts).
https://www.pugetsystems.com/support...d-use-it-1842/
In other words, it works just like PT's cache. My other sample drive is M.2 PCIe 4. In all, I've never had audio/sample streaming issues. I don't even remember any issues back in the day when WD blacks were the thing for audio and samples.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
  #7072
Old 02-21-2023, 06:18 PM
LDS LDS is offline
It's not worthwile to Hackintosh IMO, the newest CPU's are not supported by Apple so dunno how much work it would be. I wouldn't do it for a work machine.
I have a Raptor Lake based dual boot hackintosh here. It is easily the best system I have used by a long margin, and it only took about 3 hours from bare parts to full build with Win10 and MacOS Ventura. The tools seem better than ever, really.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
  #7073
Old 02-22-2023, 02:00 AM
Skwaidu Skwaidu is offline
That's impressive, I wouldn't dare to do it (and I'm actually super happy not having to use macOS any more). How many OS updates will you get, and what is the OS update process like, though?
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3
Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1
HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES.
  #7074
Old 02-22-2023, 04:37 AM
LDS LDS is offline
If you have no need to do it there probably isn't much to gain. I spent more time trying to troubleshoot bluetooth issues in Windows than it took to setup the entire MacOS partition. It probably depends a lot on hardware choice though. Some of the tools have gotten pretty amazing, like single button clicks to generate windows bluetooth keys so that my Apple magic mouse and keyboard seamlessly work across both Windows and MacOS partitions. So far the updates have just been done using the software update tab in MacOS just the same as any other mac computer.
I don't have a crystal ball as far as future updates, etc. That is the main reason I built it! Most of the film/television/radio portions of the industry haven't gotten anywhere near grappling with the Apple Silicon transition yet. It will probably take a few years to pan out. I figure 2-4 years with this machine and the dust will hopefully have started to settle. Where it settles is anyones guess!
  #7075
Old 02-22-2023, 12:14 PM
Okay, interesting. Luckily I don't need BT, have USB extenders from my machine room. And agreed on the post industry being still in dissarray re: ASI - I'm also a score mixer myself but I seem to be fine on Win with just running Macdrive here.
BTW you came to mind while I was reading the DAWBench test thread on GS - on the last few pages an user has popped in claiming that they are seeing a massive CPU efficiency increase in both Cubase and Studio One, on a i7-8700K Hackintosh. Have you happened to test PT performance on both OSes? If you had, it would be amazing if you shared the results here or in that thread. Any standard plugin loading test with identical PT settings (and the same audio interface) would suffice for "proof of concept" IMHO, it would be interesting how your results compared to this user (whose first language clearly is not english...)
The thread is here, I'll link to the page with the first post by user "AsiashA" on the matter, a lot of discussions about it on the following 2 pages, also with comments from TAFKAT (one of the DAWBench crew) and Psychlist (Microsoft's audio dev Pete Brown):
https://gearspace.com/board/music-co...hmarks-35.html
  #7076
Old 02-23-2023, 01:42 PM
LDS LDS is offline
Interesting! I'll run some tests early next week and see how it pans out.
  #7077
Old 02-23-2023, 01:49 PM
Great, looking forward to any data!
Oh, if you can, super helpful would also be to explore all Playback buffers on both systems (or at least the lowest you can, and a high one). There have been some anecdotes where macOS had somewhat higher plugin counts, but Win exhibited better low latency performance.
  #7078
Old 02-27-2023, 08:13 PM
Sugarnutz Sugarnutz is offline
Anyone seen this?
56 core Intel W9 Xeon
Here’s one of the motherboards for it:
ASRock W790
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
  #7079
Old 02-28-2023, 10:13 AM
Originally Posted by Sugarnutz View Post
Anyone seen this?
ASRock W790
Hmmm, lots of cores but really slow. Then there's the price
  #7080
Old 02-28-2023, 11:44 AM
This one might be more interesting to most musicmakers
https://ark.intel.com/content/www/us...-2-50-ghz.html
I'm not sure about slow - benchmarks are not yet out but they are Alder Lake cores that boost to up to 4,80 GHz in single core loads (and can be overclocked), so they should be pretty much equal to the M2 processors (or the i5-12600K @4,90 GHz) and above any M1 in single core performance.
Multicore should be pretty spectacular, also with the 4 and 8 channels of DDR5 (benefitting VI users especially), but sure it's a pricier pro-oriented platform. Still the CPUs Apple *should* use in a Mac Pro.
Best Core 2 Series Desktops-Results and Specs sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2416 02-19-2013 07:49 PM
new to pc builds chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-18-2011 07:10 PM
any p45 builds fofif5792 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2008 12:47 PM
OSX "builds" Richard Barrie Pro Tools TDM Systems (Mac) 2 10-18-2004 08:37 AM
