Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 11-02-2023, 03:25 AM
wlldeans wlldeans is offline
Default MacBook with Carbon and CalDigit experiences
Hello, does anyone reading this have any experience using Pro Tools on a MacBook, while using a Carbon interface and a CalDigit TS4 or TS3 dock? Keen to know if you had any issues with external drives (session and sample library) that were connected to the dock. Also keen to know how you overcame the lack of AVB on the dock, did you buy something like cal digit connect 10g? I read something about a double dongle set up being the best option but it wasn't clear to me what those dongles were, whether they were connected to the dock or the MacBook.
Any feedback would be appreciated, thanks in advance.
Old 11-02-2023, 03:39 AM
dominicperry dominicperry is offline
Default Re: MacBook with Carbon and CalDigit experiences
Which MBP do you have?
It's pretty easy if you have one of the 14" or 16" machines with M1/M2/M3 chips - you just dedicate one TB/USB4 port for the Carbon and hang hubs off the other ports.
The Sonnet adapter works, as does the double-dongle. Both listed here under "Network Requirements & AVB Adapters":
https://avidtech.my.salesforce-sites...n-Requirements
I don't have the Caldigit TS3 or 4 but I do have the Elements TB4 hub and it works fine for peripherals. I also have a 7 port USB-A hub hanging off the Caldigit - also works fine. But all my samples are on internal disk.
I do have problems with external spinning disks, whether connected directly to the MBP or to one of the hubs. They keep disconnecting. This seems to be an M1/M2 problem combined with certain OS types - there's lots of similar reports. But SSDs are fine.
If it's helpful I can try the Carbon conneted to the Sonnet, connected to the Caldigit, connected to the computer.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 11-02-2023, 03:50 AM
earlsize's Avatar
earlsize earlsize is offline
I have a MacBook Pro max 16 2021 M1, a Caldigit T3 and Carbon. I took a T3 to an Apple T2 adapter and plugged in an Apple T2 Ethernet adapter and plugged in the ABV Ethernet cable. Also, Sonnetech has a T3 adapter to ABV listed here:
https://www.sonnettech.com/product/t.../overview.html
Earl Size
MacBook Pro Max 64GB ram 2TB SSD, 8TB & 4TB External SSD, Ventura 13.6.6, Pro Tools Ultimate 2024.3, Pro Tools Carbon, Apollo 8 Quad Black Lion Mod, UAD Octo, Avid S3, Avid Dock
Old 11-02-2023, 04:33 AM
Thanks for the replies, and also for the links, those have been helpful. It sounds like SSDs off the dock will do the job, it also sounds like the carbon connected to MacBooks have no issues either. I'll probably go the route of connecting the Carbon directly to the MacBook rather than off the back of the dock.
I don't have a MacBook yet, I'm working off an old Mac mini. Will probably pick up an M3.
Thanks again
Carbon and MacBook Pro 13 mid 2012 ?? mellotronik Pro Tools | Carbon 9 03-08-2021 07:44 AM
MacBook Air 2015 or earlier experiences? AxeDye Pro Tools 12 5 09-09-2015 12:55 PM
MacBook Pro experiences? lampmusic Pro Tools 11 1 08-30-2013 06:32 AM
Experiences running Eleven Rack with a USB3 MacBook Pro or MacBook Pro Retina? Darryl Ramm Eleven Rack 3 09-18-2012 11:22 PM
experiences of using 7.1.1 on MacBook (not Pro) chrisblytheuk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-13-2006 01:59 AM
