Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 01-05-2022, 10:48 AM
tonyw7 tonyw7 is offline
Default Fixed: McDsp 6050 Ultimate CS issue
Hi
When I insert the Mc DSP 6050 Ultimate CS plug-in as a dsp it gives me an AAE error-14143,
It states:
The DSP plug-in could not be made active because
an AAE error was encountered.
AAE error-14143 was encountered.
All my other dsp plugs work fine.
When I insert it as a native plug-in it works.
Any help would be appreciated.
Thanks, Tony
Old 01-05-2022, 11:38 AM
Default Re: McDsp 6050 Ultimate CS issue
Found the problem, tech support at McDsp said the dsp license has to be on an iLOK, only the native version works on the iLOK cloud.
Old 01-05-2022, 03:12 PM
eightamrock eightamrock is offline
I literally just hit this today. Perfect timing!
Old 01-06-2022, 12:56 PM
Old 11-09-2023, 07:47 AM
martthie_08 martthie_08 is offline
is anyone else having extremely long lag times when opening the plugin? I've upgraded to V7 (still on Intel though) and it almost takes about 15 seconds to instantiate the plugin.
Old 11-18-2023, 10:16 AM
plunderpot plunderpot is offline
Default Re: Fixed: McDsp 6050 Ultimate CS issue
I'm having the same long opening times with the McDsp 6060!
Issue fixed samtrino Licensing & Accounts 0 01-04-2021 11:25 AM
McDSP 6050 Stig Eliassen ICON & C|24 4 12-23-2017 02:24 AM
McDSP - ultimate 6030 compressors 5.3.09-14 Seafoam_Green AAX Plug-ins 0 03-04-2014 07:34 PM
McDSP 6030 Ultimate Compressor Native: How good is it? rockguitarist1255 Pro Tools 10 3 03-02-2013 12:09 PM
fixed one issue, can't fix another. TampaBayBrian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-02-2008 06:59 PM
