Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 12-23-2021, 05:11 AM
mlange's Avatar
mlange mlange is offline
Default Re: Carbon connected to a Mac Pro 5,1
Originally Posted by tonyw7 View Post
The Solo 10G PCie card is arriving Monday, so I should know if it works with Carbon Tuesday,, if not time to get a trash can
I was able to connect to carbon with my macbook pro mid 2015 running Catalina, but it's not what I want to use.
I found that using my (2)192 interfaces connected to the two carbon adat outputs gives me 16 outputs via the d/a outputs from the 192, plus the 8 line outs from carbon. Got to keep my old HD system now for providing the 24 outputs into my console.
edit - I think you're using your old HD system just for accessing / using the 192 i/o as a converter, right?
This is intriguing - thanks for sharing your experiences.
Did you connect two 192s via lightpipe - the blue Digi 192 i/o's? I wasn't aware the older interfaces had any sort of standalone operation mode (ie, the 192s were not connected to any host computer)?
-Mark
________________________
www.PlethoraTone.com
PlethoraTone Studio Video Tour
At PlethoraTone:
Mac Mini M1, Avid Carbon,
PSP, Waves Mercury, UAD, Kush, Slate Digital,
PA, Melodyne, Antares, Audioease, SoundToys
Old 12-23-2021, 01:39 PM
tonyw7 tonyw7 is offline
You have to have a host computer running PTHD 8 to 10 with a digi pcie core card installed to have the digi 192 work as a D/A converter.
Old 12-27-2021, 10:24 AM
It works!!!, the sonnet card connected via AVB to carbon with no issues.
I have a session open with 24 tracks, and a load of plugins,, no hic-ups
Old 12-27-2021, 10:27 AM
All hail the Cheesegrater. Best damn Apple product ever
Really neat to see you do this.
Old 10-23-2023, 06:24 AM
jayceebee jayceebee is offline
I'm trying re-up this thread because I planned to buy a Carbon card. My Mac Pro 5,1 is a 2012 machine with the sonnet ethernet card, Metal Compatible GPU AMD radeon 7970, with Bi-proc 3,46 Ghz Cpu trail and 128 go Ram under Ventura OS with open core 1.01 ...
Do you think this config is right to get carbon working well with latest release of protools ultimate ?
thanks a lot for reply, because carbon is a lot of investment for me, and it will be a huge disappointment, if oncetime at my house this don't work ...
king regards.
  #16
Old 10-31-2023, 02:15 AM
rokko101 rokko101 is offline
Hi there. I'm on the same boat as jayceebee, except running Monterey.
Can anyone confirm PT Carbon runs ok with the Sonnet Solo10G pcie card?
Thanks!
  #17
Old 10-31-2023, 09:28 AM
MCorbin's Avatar
MCorbin MCorbin is offline
This'll fall squarely on the shoulders of the Community since we do not test or qualify the 5,1 for Carbon or test/qualify any PCIe AVB cards. We've also stopped testing the 5,1 in general with Pro Tools, but expect it to work.
m
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
  #18
Old 11-01-2023, 09:30 PM
basslik's Avatar
basslik basslik is offline
king regards.
I would use Martin Lo's OpenCore package 0.9.5. I'm in the process now and mounting the EFI boot is really simple. There's even a script to have the 5,1 see and use 8x32 sticks of ram.
Also many Mac Pro's are being bricked due the Boot ROM not being dumped. Many have been bricked over the years. A must read for these beast of machines.
A must read for this machines to stay healthy.
https://forums.macrumors.com/threads...#post-26346264
A Mac Pro that the garbage collection is not working anymore will have less than 1/3 of Free Space Full Size available, less than 22000 bytes available. Any less than this and you usually start having problems and could even brick your Mac Pro. This is critical with Big Sur and Monterey Software Updates, but also happened in the past with previous macOS versions (examples #1, #2) because the number of variables needed to be set-up for the software updates.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Carbon and C24 I/O Jaz64111 Pro Tools | Carbon 1 08-25-2021 08:01 AM
Carbon and Mac M1 / Big Sur and other ?’s darkwavo Pro Tools | Carbon 31 05-01-2021 12:57 PM
Carbon with anything other than 10.15.7? Matt Hepworth Pro Tools | Carbon 12 01-08-2021 07:14 AM
MBox connected but PTLE says NOT connected ludaben 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-05-2004 10:01 PM
