Old 07-19-2009, 08:53 AM
J2sound J2sound is offline
Default Mono Plug In on Mains
I'm trying to tune the L/R of the Mains separately but I don't know how to put a mono plugin on left and one on the right. Any suggestions?
Justin
Old 07-19-2009, 10:07 AM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: Mono Plug In on Mains
Hi Justin,
The LR bus is a stereo bus, so only stereo plug-ins can be inserted. To tune each side separately, route the L bus to one mono matrix, the R bus to a second mono matrix, and then insert mono plug-ins on each of the matrixes.
Sheldon
Old 07-19-2009, 10:20 AM
Should I just set the gain on the matrix to 0.0dB?
Justin
Old 07-19-2009, 10:57 AM
It depends on where and how you want to control the master level.
The easiest approach is to set the input gain for the L and R buses within each matrix to 0 dB, and set the matrix masters to 0 dB. The default pickoff point for the matrixes is post-fader (Options>Pickoffs), so this means any change to the Mains LR fader will also affect the level being sent to the matrixes (which is normally what you'd want).
Sheldon
Old 07-19-2009, 02:41 PM
emluper emluper is offline
Hey Sheldon,
Doesn't he then have to take his outputs to the mains from the matrices and not the L/R outs?
Old 07-19-2009, 03:26 PM
Correct. The matrix outputs must now be patched (in the Patchbay) to the physical outputs of the console, which then connect to the inputs of the downstream amp/speaker processor.
Sheldon
Old 07-19-2009, 03:35 PM
Scott Fahy Scott Fahy is offline
I have been using the Matrix outs as my final drive for about a year and like the extra flexibility. We use aux fed subs and front fills and the system sounded better when I pulled the left center right down 3 to 6 db in relation to the subs. I realize I could have done it in the system DSP but not all the operators use the matrix as there final outs.
Scott
What are the difference between using a "mono" vs "mono/stereo" plug in on mono track rockguitarist1255 Pro Tools 10 4 12-07-2012 08:07 AM
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 07:33 PM
Multichannel plug-in vs Multi-mono plug-in? rcook349 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-16-2007 09:45 AM
mono to stereo plug-in Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-23-2004 01:01 PM
How do you keep a mono/stereo plug-in mono? Baixo Tips & Tricks 8 01-05-2001 11:03 AM
