Output delay on bus ??
Hello,
Somebody knows why we can't use delay output on Bus? It will be really usefull in theatre configuration. I should probably use Matrix output but it's not usefull. Thanks for news Brousse France |
Re: Output delay on bus ??
Can you just route your L/R to a Matrix and use the delay there? You mentioned it in your post, and that would work. You just jump through one extra hoop before audio exits the console, but you can delay as you please.
I believe there is a plugin also that can impart delay on a signal. Some of the DigiRack plugins have this capability. Could you insert those on your main bus? What are you trying to acheive specifically? Maybe we can give a little more detailed advice if we know more what the end result needs to be... Hope that can help a little... |
Hi Brousse,
More delay options would be useful at times. Make your groups variable then use these as auxes for things that don't need delay. This'll free up true auxes to use like sub groups. For speed set all the auxes to 0db on all channels then use the on off as a route button. |
DeckLink HD Extreme 3D Output Delay | HenningM | Post - Surround - Video | 2 | 11-28-2012 01:38 PM |
Input output delay compensation with 3rd party interface | propower | Pro Tools 10 | 13 | 11-12-2011 02:32 PM |
Sessions seem to be shifting phase on L/R output Delay comp errors. | soundeq | macOS | 4 | 11-03-2011 12:31 AM |
viewing total output delay | vikingthor | VENUE Live Sound Systems | 0 | 08-14-2010 05:03 AM |
Delay in monitor output when recording live | rocky Jackson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-03-2008 05:39 PM |
