Old 04-22-2001, 11:03 AM
toecat toecat is offline
Default Digi 001/Logic/OMS
I am trying to setup Logic to run midi. I am using the Digi 001 hardware, and the 001 midi ports. Do I need to use OMS to run this setup or is there a way not to use OMS? If so which way is better?
Toecat
Old 04-22-2001, 08:39 PM
gangbanga gangbanga is offline
Default Re: Digi 001/Logic/OMS
You should be able to set it up in Logic using the multiport window (I think it's called multi port) without using OMS. peace
Old 04-26-2001, 04:22 PM
I found out from Emagic. To use the 001 for midi you must use OMS. Emagic had a driver for the 001 but was not stable.
Toecat
Digi 002 & Logic Pro Bronxite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-21-2006 09:00 PM
Logic and Digi 002 Makkan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-23-2004 04:47 AM
Digi 002 w/Logic and/or DP3 sirgant 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-15-2002 07:29 AM
Digi 001 + Logic ncorea 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-10-2002 09:29 AM
DIGI 001 & Logic AP 4.5 Imox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-11-2001 07:39 PM
