Old 11-19-2021, 02:08 AM
Paulienat's Avatar
Paulienat Paulienat is offline
Default Importing a group of Tracks with all the related Playlist's list
Hi, I have to import to a new session a group of 3 tracks from another session.
I need to import each track with its own list of playlist...without the audio clips, I only need the playlist track and name to put different clips without having to create and rename again all the playlists.
If I use import session data, unchecking the "import audio-clips" box, I have all the tracks but I don't have all the playlists for each track.
I tried using track presets with no success. Best way to get also the playlists when I import tracks (with no audio-clips). Tks
Old 11-19-2021, 03:47 PM
cwsand's Avatar
cwsand cwsand is online now
Default Re: Importing a group of Tracks with all the related Playlist's list
Hi, Where exactly are you seeing a "import audio-clips" box? I don't see one in my Import Session Data window.
You can select "Track Data to Import", but if you unselect Clips and Media, you lose the option of importing playlists.
Only way I know how to do it is to import the tracks with the corresponding media. Under Audio Media Options, you can choose "Link to source media" or "Copy from source media". The Link to option is the fastest since Pro Tools doesn't have to copy the audio from the other session. Then you can just delete the audio clips - but be careful not to permanently delete the audio from the original session!! (Yes, I've done this!) Best to make a backup of the original session before doing this to be safe.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Group of clips not importing correctly from Clip List? ebban Pro Tools 12 0 08-31-2017 01:25 PM
PT10 group issue (cant find related thread) lvly5t Pro Tools 10 3 03-11-2017 04:48 AM
Export Pro Tools "Playlist" tracks as a new session or Split Playlist into new Tracks AMIEL Pro Tools 12 1 12-08-2016 01:48 PM
Importing Tracks as a Group Lou21 macOS 1 04-08-2013 12:42 PM
Playlist bug help (multiple tracks in group midi issue) Seti Orion Pro Tools TDM Systems (Mac) 3 04-24-2008 12:52 PM
