The blinking stop button problem
As many other have experienced, I'm dealing with the blinking stop button problem. When I hit the play button, both the play and stop button blink and I got no playback. But there's more. It only happen when my buffer size is at 1024. But when I go to a lower buffer size, I got tons of click and pops cause I'm using Komplete and it seems my cpu is having a hard time keeping up. So the solution would be to go to a higher buffer size, but there it is. The stop button problem. And yes it does that on all my sessions. A week earlier, everything was fine. Pretty damn annoying. Would appreciate your help! Thanks! Ben |
Re: The blinking stop button problem
Lenovo Thinkpad T510
Win 7 i5 4g ram Pro Tools 9 Macke Onyx Blackjack 2x2 |
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
SiSoftware Sandra
ID Host Name : Poste-PC Workgroup : WORKGROUP Computer Model : Lenovo 4313CTO ThinkPad T510 Serial Number : R9B7EX3 Chassis : Lenovo Notebook Mainboard : Lenovo 4313CTO Package : FC PGA988 Serial Number : 1ZJGE11W2F8 BIOS : Lenovo 6MET81WW (1.41 ) 10/26/2010 TPM - Trusted Platform Module : 1.02, STM Total Memory : 3.8GB DDR3 SO-DIMM Processors Processor : Intel(R) Core(TM) i5 CPU M 560 @ 2.67GHz (2C 4T 2.8GHz/3.19GHz, 2GHz IMC, 2x 256kB L2, 3MB L3) Chipset Memory Controller : Lenovo Core (Arrandale) Mobile DRAM Controller 133MHz, 2x 2GB DDR3 SO-DIMM 1GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : Ramaxel RMT3020EF48E8W1333 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Ramaxel RMT3020EF48E8W1333 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : Intel(R) HD Graphics (12 SM4.0 767MHz Turbo, 66MB DDR3 1GHz 128-bit, Integrated Graphics) Video Adapter : Intel(R) HD Graphics (12 SM4.0 767MHz Turbo, 66MB DDR3 1GHz 128-bit, Integrated Graphics) Graphics Processor Storage Devices WDC WD5000BPKT-00PK4T0 (500.1GB, SATA300, 2.5", 7200rpm, 16MB Cache) : 466GB (C:) (D:) Seagate ST1000LM010-9YH146 (1TB, USB2/SATA300, 3.5", 5400rpm, 16MB Cache) : 932GB (F:) Lexar USB Flash Drive (8GB, USB2) : 7GB (G:) Optiarc DVD RW AD-7700H (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices SYSTEM_DRV : 3GB (NTFS) Disque Mou (F:) : 932GB (NTFS) @ Seagate ST1000LM010-9YH146 (1TB, USB2/SATA300, 3.5", 5400rpm, 16MB Cache) Removable Drive (G:) : 7GB (NTFS) @ Lexar USB Flash Drive (8GB, USB2) Hard Disk (C:) : 453GB (NTFS) @ WDC WD5000BPKT-00PK4T0 (500.1GB, SATA300, 2.5", 7200rpm, 16MB Cache) Recov (D:) : 10GB (NTFS) @ WDC WD5000BPKT-00PK4T0 (500.1GB, SATA300, 2.5", 7200rpm, 16MB Cache) Optical Drive (E:) : N/A @ Optiarc DVD RW AD-7700H (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Lenovo QM57 LPC Interface Controller Audio Device : Lenovo P55/PM55/3400 High Definition Audio Audio Codec : Conexant 5069h Serial Port(s) : 1 Disk Controller : Lenovo P55/PM55/3400 6 port SATA AHCI Controller Disk Controller : Lenovo PCIe SD/MMC Host Controller USB Controller 1 : Lenovo P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : Lenovo P55/PM55/3400 USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Lenovo FireWire Host Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Peripherals Media Player : Lexar USB Flash Drive (7.47GB) Network Services Network Adapter : Intel(R) 82577LM Gigabit Network Connection (Ethernet) Wireless Adapter : Intel(R) WiFi Link 1000 BGN (802.11g (ERP), 130Mbps) Power Management Battery No 1 : Panasonic 42T4801 90.98Wh/7.46Ah Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.6 |
Not sure exactly what's causing it, but it could be a plugin issue. What other plugins do you have running in the session? Does it happen if you deactivate Komplete or any of the other plugins? Try trashing preferences. You could also try adjusting the other buffer settings in the playback buffer screen. Have you performed all of the Windows 7 optimizations?
Did you accidentally hit the Wait for Midi note button? Its the little clock face at the left of the transport buttons. Beyond that, the Lenovo has a few issues to consider. Integrated graphics are often a show stopper for PT. Wifi should be disabled when running Pro Tools. One way to help rule out a plugin is to hold the SHIFT key while opening a session. That will make all plugins inactive so they SHOULD have no affect on Pro Tools at all. If things play fine that way, then its trial and error to find the offending plugin.
Ok so I tried pretty much everything you said :
Trashing preferences : Didn't worked Wait for midi note : Not activated Deactivating all plugin (holding shift) : Didn't worked Tried all the buffer setting in the playback engine menu : Neither I did not performed all of the Windows 7 optimizations but everything was working fine before and I never did those so I guess it's not the problem. Thanks though. Any other advice? |
Are you recording to the Seagate drive? Its 5400 rpm and too slow for recording.
No I'm not. And I'm not sure this is related to my problem. I have a playback issue, not a performance issue.
Playback issues are often performance issues...
Music won't play. Play button flashes and Stop button lights up | Mattitude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 04-16-2020 03:03 PM |
Blinking STOP/PLAY transport buttons PLAYBACK ISSUE | guitarman6 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 27 | 08-14-2019 12:26 PM |
Cannot record / stop button | jglover51 | Pro Tools M-Powered (Win) | 0 | 03-29-2008 04:20 PM |
Stop button question | Nigel Howard | Pro Tools TDM Systems (Mac) | 3 | 09-08-2004 04:29 PM |
