Old 07-15-2008, 05:57 AM
Heidistonemail Heidistonemail is offline
Default Vienna Symphonic Library (VSL) - getting error -6097
Hi - I've recently purchased the VSL Special Edition and am using the VSL as a RTAS plug-in. I've not been able to use the program though b/c I keep getting a Hardware Buffer size error (-6097). Pro Tools freezes after a couple of minutes and the error message pops up. I've maxed out my HW buffer size to 1024 samples and am using both cores (RTAS Processors: 2, which is my max) in my computer with 99% CPU usage.
Am I just out of luck with this software? I have 15 other Virtual Instruments on which there is absolutely no problem. Is there a work-around using another computer as a VSL "slave" to my MacBook Pro? Would it need to be a Mac? (I have a Dell PC that I used to use for PT work but after the switch to Mac, I'm just using it for gaming - so it it is available for use.) I'd be grateful for any suggestions.
Equipment:
Pro Tools LE 7.4, with a 003 Rack Factory
MacBook Pro (2.33Ghz Intel Core 2 Duo 3GB memory)
Tiger 10.4 with two external hard drives - one with 1TB and the other with 250GB - the VSL Special Edition content (other than installer, program, and Directory Manager) are on the 1TB external hard drive
Actions so far: Trashed the Preferences, increased/decreased CPU usage limit, decreased RTAS processors to 1 (from 2), increased/decreased HW buffer size
thanks, H.
Old 07-25-2008, 07:32 AM
dayadon dayadon is offline
Default
Equipment:
thanks, H.
Hello.
I'm fairly new to PT, but I've started using Vienna SE, and things are loading and running very well so far.
My VI plugin shows up as RTAS also in PT. I've not done any special setups in VI SE, but I had to do the things you said, like go to 1 processor for Kontakt, and other things.
I'm using a Mac Pro with 6 gigs of memory, and an external Firewire 800 for all my samples. My operating system is OS X 10.5.3. I tried using 10.5.4, but odd things were going on with PT for me.
I made sure I have all the latest updates from Vienna, too.
It's a nice sounding plugin, so I hope you can get it going!
Dennis
Vienna Symphonic Library Siegfried Meier Pro Tools TDM Systems (Mac) 13 02-16-2009 11:17 AM
Vienna Symphonic Library - Anything similar? Composers help! Clint Hernandez Virtual Instruments 7 01-21-2008 09:08 PM
Vienna Symphonic Library and Pro Tools? Chris Avery 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-23-2006 05:42 AM
Vienna Symphonic Library and Pro Tools? Chris Avery General Discussion 0 01-22-2006 08:24 PM
Vienna Symphonic Library The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-09-2003 07:20 AM
