Old 07-17-2003, 11:23 PM
Moses Presley Moses Presley is offline
Default Mono, but no "Beatle Stereo"
I'm trying to capture that old pre-stereo sound as in Beatles tracks, where stuff is panned far left or far right, and can only be heard in one speaker or the other.
Thing is, I record all my tracks in mono, put a mono master fader in, and pan them hard, but when I listen (to both pre-bounced mixes and bounces mixes), everything is in both speakers.
HELP! Anyone have any ideas?
MP
Moses P.
Old 07-18-2003, 12:51 AM
gigi gigi is offline
Default Re: Mono, but no "Beatle Stereo"
Put a STEREO Master fader and set the position (left or right) of the signals from the pan of the single mono tracks.
Hope this helps
Ciao
Gigi
Old 07-18-2003, 12:54 AM
jonnyrocker jonnyrocker is offline
The Beatles sound I believe you are describing is still stereo. The parts are hard panned because they had to create submixes to accomodate many overdubs on their four-track tape machines. The final mix is still on two tracks (right and left), allowing you to hear things panned.
It sounds like you just need to use a stereo master fader. Then pan your mono tracks hard. To mimic the submixed sound, try hard panning every instrument one way or the other.
Good luck.
Old 07-18-2003, 05:26 AM
Hmm...when I create a Stereo Master Fader, the Master Fader itself has no option to pan. Is that right?
I bounced Stereo after setting up the Stereo Master Fader, and the results are the same. Everything is still in every speaker. Where else could I be going wrong?
Also, I may have one or two tracks that AREN'T panned hard...would they all have to be to achieve the effect?
MP
Moses P.
Old 07-18-2003, 06:19 AM
apetrocelli apetrocelli is offline
You have to pan EACH of the track either left or right, depending on which speaker you want them to appear. FOr example, pan bass, r. guitar and drums hard left, lead guitars and voices far right.
Then use a stereo master fader, not a mono one. The Beatles sound is not pre-stereo, actually is very stereo in that you don't hear the same thing on both speakers. Wherever you put a mono device in your signal, that effect will be lost. Some people has the theory that they mixed that way to show the effect of the new stereos in a more radical, comercial way. Who knows.
Cheers, Andrés
Old 07-18-2003, 10:07 AM
Okay (and I'm sorry if my line of questioning is stoopid), should I also make sure all the plug-ins are stereo as well.....or mono (all the tracks are mono)?
MP
Moses P.
Old 07-18-2003, 10:43 AM
Hey Moses, no problem.
The tracks are mono, hence the plugs should be mono too. If you want to blend both channels a little you can try and use a stereo reverb on a stereo auxiliar channel. For example put a stereo auxiliar whose input is Sub 1-2, and make all the Aux Sends of the left tracks go to Sub 1, and then all Aux sends of the right tracks go to Sub 2.
Cheers, Andrés
Old 07-19-2003, 06:13 AM
ghostman420 ghostman420 is offline
Originally posted by apetrocelli:
Some people haVE the theory that they mixed that way to show the effect of the new stereos in a more radical, comercial way. Who knows.
Cheers, Andrés
<font size="2" face="Verdana, Arial">I know. They mixed and recorded that way because they didn't have any other options. They only had four-track tape machines to work with. Thank goodness for Les Paul and George Martin! It wasn't to show off the new stereophonic sound (which wasn't exactly new at the time anyway).
eMac
700 Mhz
640 RAM
M-box
PT 5.2
Old 07-19-2003, 09:11 AM
Yup. I've heard the same thing. All I know that throughout music history and everything that has come and gone, I still love listening to the production of those Beatle records. Not just the songwriting, but the production. Listening to songs only in one speaker, etc.
Hey thanks, guys. I'm going to try those tips out today.
MP
Moses P.
Old 07-19-2003, 05:46 PM
jeffinmarin jeffinmarin is offline
Hey. I think stereo records started in 1958. The Beatles came round in 1963.
jeff
Consolidate vs Duplicate - "Stereo" vs. Dual Mono Behaviour rnd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-05-2013 01:03 AM
What are the difference between using a "mono" vs "mono/stereo" plug in on mono track rockguitarist1255 Pro Tools 10 4 12-07-2012 08:07 AM
HOW can you import a "stereo" WAV. file into PT as a "mono" file? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2002 09:14 PM
What do i import a "dual mono" audio file as??? mono or split stereo? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-17-2002 04:02 AM
"STEREO" Mono Pair aurelio funk dias Post - Surround - Video 2 06-13-2002 08:27 AM
