Pro Tools 11 Hardware Insert Not Working
I'm not able to get a signal back into Pro Tools Vanilla 11.3.1 with UA Apollo Hardware. Is this because of the lack of input monitoring in PT11?
Everything is routed correctly - I've verified that signals are getting to the interface but they are not showing up in Pro Tools! I've tried the obvious enabling / disabling auto-input monitoring with no luck. How do I enable input monitoring with this version of PT? thanks in advance, |
Re: Pro Tools 11 Hardware Insert Not Working
Jack -
Thank you, that worked! I forgot about the two null pathways at 1&2 on the Apollo. I set the insert back two channels and all came up perfectly. Much appreciated! J |
Glad it helped - it's one of those features that's not well known as is the ability to have PT see whatever I/O you want it to see so you aren't limited to the first 32 I/O like with other interfaces.
Hardware Insert Latency issue in Pro Tools 10!!! HELP !!! | Hovak | macOS | 14 | 10-28-2012 10:42 AM |
pro tools 9 insert hardware??? | katch22 | Pro Tools 9 | 10 | 12-25-2011 11:53 AM |
Pro Tools 9 Hardware Insert Delay Compensation with Lynx AES16e and Aurora 16 | SolutionRoom | macOS | 0 | 04-08-2011 10:54 AM |
hardware insert with pro tools 9 motu 24 i/o | glideman | macOS | 1 | 12-22-2010 09:18 PM |
Pro Tools 7.4 Hardware Insert Question | Jaylaca | Pro Tools TDM Systems (Mac) | 2 | 02-12-2010 07:38 PM |
