PlugIns Disappeared
Hello,
Just booted up PT11.2.1 this morning and 99% of my plugins are not there! They still exist in Library/Audio/PlugIns, but not in the PT interface. Only a few are there (Ableton, Reason etc), but all the Avid plugins and 3rd party plugins are missing. Any thoughts? It was all ok yesterday. Thanks, bb |
Re: PlugIns Disappeared
Has to be corrupted preferences. Time to trash 'em.
This app makes it easy to trash them and then back up the new ones once you've reset everything. http://duc.avid.com/showthread.php?t=340741
Ron Wasserman http://www.ronw.com http://www.imdb.me/ronwasserman http://www.fishertheband.com Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version. |
Thanks - just one thing - the plugins work ok in Pro Tools 10...just not 11... |
PlugIns Disappeared
So the preferences in 11 are messed up, just go trash prefs for Pro a Tools 11 and report back.
ok, will do
On a Mac the path for PT11 plugins is: MacHD/Library/Application Support/Avid/Audio/plugins |
I'm using an iMac (2013), Mavericks 10.9.5, 3.2 GHz Intel Core i5 Pro Tools 10.3.8 and 11.2.1, audio interface Mbox2. best, bb |
Have you looked in the path I wrote to see if your plugins are there? They have to be in that specific location. Something that can screw up a PT install is what was installed first. Generally install PT10 and it's plugins first and then install PT11 and it's plugins. PT11 uses some of the things installed by PT10 I've found and installing PT11 first can cause issues. Fortunately reinstalling PT is easy. Except doing an uninstall of PT10 on Mavericks as the uninstaller doesn't work. You have to do that manually and that info can be found here by a forum search. |
Similar issue in ProTools 10 after installing on new computer.
I am having problems loading the virtual instruments Mini Grand and Boom. In both cases, I'm asked for a path. When I provide it, can load the instrument once. But next time I open the session -- or even after changing instruments in same track -- am asked same question again. In the case of Mini Grand, I have to quit ProTools before I can again load Mini Grand. Boom is more forgiving, lets me again indicate the path, then loads. Other Avid virtual instruments, including Xpand, load OK, but I am having activation issues with some Native Instruments plug-ins. MacBook Pro 10.9.4 Mavericks, 8 GB ram. ProTools 10.3 |
Thanks all, this is hugely helpful (and sorry if you're having the same issue, I sympathise). I'll give all your advice a go and get back to you,
best, bb |
One bug disappeared, a new one came! | clausiii | Pro Tools 11 | 6 | 02-14-2014 10:25 AM |
Why have my windows disappeared? | babygoboom | macOS | 0 | 02-11-2014 10:51 AM |
plugins disappeared | yurtpoh | Pro Tools 11 | 1 | 07-05-2013 04:38 PM |
HD on Mac disappeared | stevegalante | Storage Subsystems | 10 | 08-17-2012 01:51 AM |
Help: My 192 has disappeared! | alanbuf | macOS | 1 | 01-03-2012 04:51 PM |
