Old 03-17-2018, 10:04 AM
ZdonTheRapper ZdonTheRapper is offline
Default how to snap timeline/cursor to grid
Hello, so I'm editing out breaths and would like to be able to use only my keyboard when doing so. I figured out how to nudge the cursor and nudge my selections according to the grid/nudge value, however, when I playback audio for a second to see where I am and what I'm editing, it will stop outside of the grid lines. I know about using insertion follow playback or shortcut n to make the cursor not return back to where you started playback from. I want this selected so I can just hit play and stop at where the next breath is and edit from there. But the problem I'm having is when I stop the track, it lands in a position that is outside of the grid, so whenever I use the "nudge what is selected" function it nudges according to the grid/nudge value, but the selection will start and end outside of the grid. So I was wondering if there was a shortcut, or way, to get the cursor/timeline to snap to the grid from where it is so the selections I make will be according to the grid? Thanks in advance.
Old 03-17-2018, 10:41 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: how to snap timeline/cursor to grid
Do all the breaths fall perfectly within the Grid? If so, that's some mighty fine breath control.
Why not just use Slip Mode and trim out/delete exactly what you need?
I do a lot of breath removal and have never tried to do it using Grid as no space between breaths is ever the same or exactly aligned with the grid.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Edit Mode difference between: Grid and Slip+Snap to Grid zenstone macOS 0 02-05-2015 04:34 AM
Snap edit cursor/playback location to nearest grid? centerauctions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-10-2011 02:26 PM
Grid BUG - PT fails to snap to grid when zoomed out 25ghosts Pro Tools TDM Systems (Mac) 0 04-18-2009 07:54 AM
6.4.1 Grid Mode often does not snap to grid???? Philthy Pro Tools TDM Systems (Mac) 4 05-24-2005 03:25 PM
Timeline Mystery-why PB doesn't snap to #9 line? DVDave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-11-2004 01:37 AM
