PT LE 6.7 to 6.9.2 w/Mac OS 10.4.2
i am moving from a 400 MHz G4 to a new G4 powerbook 1.5 GHz w/1.25 GB of memory... i had a registered version of PT LE 6.7 installed on my old computer and i was attempting to install it on the new one before upgrading to 6.9.2. unfortunately, i can't successfully install 6.7. i keep getting the following error:
Application Launch Failure The application "Pro Tools" could not be launched because of a shared library error: "3<Pro Tools PPC dbg><DAE><DSI><DsiWriteHostRegister>" i have tried several times with the same results. in between attempts, i've repaired permissions, restarted and run Disk Warrior but no luck. oh yeah, i've got an original MBOX... any ideas? jeff mercel |
Re: PT LE 6.7 to 6.9.2 w/Mac OS 10.4.2
Are you installing 6.7 from the PTLE install CD, or migrating everything from the old computer?
If your PB is new, it must have Tiger, and 6.7 won't open in Tiger, so run the 6.9.2 update first before opening PTLE.
Dual 2.0 G5, 10.4.6, PTLE 7.1, 002R |
