Pro Tools error regarding buffer size
Hi all,
I'm fairly new to this so please forgive my naivety and lack of knowledge. I recently purchased an Mbox 2 Mini along with Pro Tools LE 7.3 (which I updated to 7.3.1) to allow me to record some guitar. However, whenever I attempt to record or playback I get an error after random intervals of time stating that: "The operating system held off interupts for too long. If this occurs frequently, try increasing the "H/W Buffer Size" in the Playback Engine panel. (-6086)" I've gone through all of the trouble shooting and simply do not know how to fix this problem. I've tried every combination of buffer size to no avail. My computer has a 3.4Ghz processor with 1GB of RAM. I know that my system uses the Intel(R) 915 Express Chipset family and as far as i know this chipset is supported. I'm not really sure what other system information might be relevent to this problem. If anyone can assist me with this problem I would be most grateful. Thankyou in advance. |
Re: Pro Tools error regarding buffer size
Ok my apologies, must have missed that bit.
I'm not too sure which system details are relevant so here's most of them: System Processor Model : Intel(R) Pentium(R) 4 CPU 3.40GHz Speed : 3.40GHz Cores per Processor : 1 Unit(s) Threads per Core : 2 Unit(s) Internal Data Cache : 16kB Synchronous, Write-Thru, 8-way set, 64 byte line size, 2 threads sharing L2 On-board Cache : 1MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector, 2 threads sharing Mainboard Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus MP Support : 1 Processor(s) MP APIC : Yes System BIOS : Intel Corp. CY91510A.86A.0031.2005.0128.0818 Mainboard : Intel Corporation D915PBL Total Memory : 1022MB DDR2-SDRAM Chipset 1 Model : Intel Corporation 82915G/GV/GL/P/PL/GL/910GE/GL Grantsdale Host Bridge/DRAM Controller Total Memory : 1GB DDR2-SDRAM Video System Monitor/Panel : Plug and Play Monitor Adapter : NVIDIA GeForce 6600 GT MultiMedia Device(s) Device : Creative SB X-Fi Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Home 5.01.2600 (Service Pack 2) Platform Compliance : Win32 x86 Network Services Adapter : NETGEAR 108 Mbps Wireless PCI Adapter WG311T Physical Storage Devices Removable Drive : Floppy disk drive Hard Disk : ST3160827AS (149GB) CD-ROM/DVD : BENQ DVD DD DW1640 (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr) Logical Storage Devices Hard Disk (C:) : 149GB (101GB, 68% Free Space) (NTFS) CD-ROM/DVD (D:) : N/A 3.5" 1.44MB (A:) : N/A ProTools File Extension Information Extension : .ptf Document Type : Pro Tools Session File Type Description : Pro Tools Session File Supported Shell Commands Open : "C:\Program Files\Digidesign\Pro Tools\ProToolsLE.exe""%1" Shell Server Application File Types : Application Operating System(s) : Windows NT File Description : Pro Tools Application File Version : 7.03.01.123 Product Description : Pro Tools® Product Version : 7.03.01 Manufacturer : Digidesign, A Division of Avid Technology, Inc. Copyright : ©1992-2007 Digidesign, A Division of Avid Technology, Inc. File Size : 26MB File Date : Friday, 15 June 2007 I hope that this is the information that you need. Thanks again. |
The chipset is your main problem, but there are a number of other issues; using only using one physical hard drive, wireless network card, and a few other minor things. There are two possible solutions to your chipset problem: some people have had luck using a powered USB hub to plug the mbox into. The other solution would be to get a new computer that is compatible with Pro Tools. Once you get a solution to the chipset problem, you are still going to need a separate physical hard drive for your audio sessions, and you will need to disable the wireless when using Pro Tools.
HEY EVERYONE, I HAVE AN MBOX HOOKED UP TO MY MPC1000 AND MY DELL LAPTOP E1505 WITH AN
Intel(R) 955XM/945GM/PM/GMS/940GML Express Processor to DRAM controller-27A0 AND JUST LIKE THE GUY ABOVE ME I KEEP GETTING A POP-UP MESSAGE TELLING ME THE BUFFER SIZE MUST BE INCREASED, WHEN I INCREASE IT TELLS ME TO REDUCE THE BUFFER SIZE, DOES ANYONE KNOW IF MY CHIPSET IS COMPATIBLE WITH THE MBOX? |
Which second hard drive are you using? Seeing how you are using a laptop, I'm assuming you have an external firewire drive right?
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
no i didnt know i needed one
so can anyone tell me how i can get my pro tools session up and running ?
Did you get a dedicated hard drive for your sessions yet?
pro tools 11 buffer size error | dhyowi | Pro Tools 11 | 1 | 11-06-2014 04:23 PM |
Pro Tools error change buffer size | charlton | Windows | 6 | 12-10-2012 04:55 AM |
G5 with Pro Tools 8 cpu/buffer size error | Kennettalex | Pro Tools M-Powered (Mac) | 0 | 10-23-2012 06:38 AM |
G5 with Pro Tools 8 cpu/buffer size error | Kennettalex | Pro Tools M-Powered (Mac) | 0 | 10-23-2012 06:37 AM |
G5 with Pro Tools 8 cpu/buffer size error | Kennettalex | Pro Tools M-Powered (Mac) | 0 | 10-23-2012 06:36 AM |
