Old 09-13-2000, 08:46 PM
paulod paulod is offline
Default 001\'s gone from the sound control panel
Hi y'all: the 001 has disappeared from my sound control panel--only the internal option remains.
I haven't used the 001 as output for the computer sounds for awhile, so I don't know when it disappeared. I know this seems elementary, but the solution has been eluding me for a couple of hours.
So I thought I'd submit my little problem to the collective wisdom of the DUC. I tried following a few threads, but they seemed to be more about the cd audio out issue (which I also wouldn't mind a summary of, if someone's got time to clue me in).
I have a B&W G3, 8.6
Old 09-16-2000, 02:32 AM
obseco obseco is offline
Default Re: 001\'s gone from the sound control panel
Do you have all the Digi extensions loaded?
Old 09-16-2000, 08:09 AM
Mat Mat is offline
I think you need OS9 to use the Digidesign control panel to route the 001.
Old 09-16-2000, 07:33 PM
Hi again folks. Thanks for your suggestions. Digi Tech Support came through with the answer (in only a day!)
"Remove the Digidesign Control Panel, install the Digi Output Drivers in the System Folder>Extensions folder and restart the computer. You can get *this extension from the Pro Tools 5.0 CD ROM in the System Folder Items folder.
Best regards,
Digidesign Technical Support"
Sound Control Panel stefano manelfi Pro Tools TDM Systems (Mac) 0 09-28-2003 06:51 AM
do i need the digi sound control panel? roseberrye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-22-2002 04:32 PM
Sound Control Panel Problem fire2k2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-03-2002 06:54 AM
sound control panel elgrecco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-28-2000 09:09 PM
No Sound Control Panel in Mac OS 8.5 gqkelly General Discussion 6 06-23-1999 12:09 AM
