Old 06-29-2004, 05:46 AM
gaston13 gaston13 is offline
Default Help w/ Digi Control Panel
I recently reinstalled PT 5.1.1 on my Mac G4 (9.2.2). When I access the "digi" Control Panel in the Mac's "Control Panel" menu, the control panel window comes up but when I click on "setup hardware" nothing happens. I've reinstalled just the "digi control panel" 2x now. Anyone else with this problem?
Old 06-29-2004, 12:42 PM
DigiTechSupt's Avatar
Default Re: Help w/ Digi Control Panel
What hardware of ours do you have installed? Does Digidesing show up as an option in your Sound Control Panel?
*What to do when the Sound or Output drivers do not appear in the Monitors and Sound Control Panel:
The Sound CDev is required to select the Digidesign hardware for sound input/output. Mac OS 7.6.1 and higher doesn't automatically install the Sound CDev in the System Folder, but instead places it in the "Apple Extras/Sound Control Panel folder". To install, drag it onto the System Folder and Restart the computer.
This information is from the downlaod area here:
http://www.digidesign.com/download/sndrvr/
You may aslo want to try donloading a frsh copy of the control panel.
Thanks,
Digidesign Tech Support
Avid Audio Tech Support
Support FAQ
Digi 002 command 8 control panel Oompah ProControl, Control|24, Command|8 2 05-18-2004 08:27 PM
do i need the digi sound control panel? roseberrye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-22-2002 04:32 PM
Digi Control Panel & iTunes EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-04-2002 03:47 PM
Digi Settings in Control Panel JPS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-19-2001 02:23 PM
Digi Control Panel Problem tomhartman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-24-2000 08:30 AM
