Old 12-06-2021, 07:29 PM
Focuret Focuret is offline
Default Updated to HD Driver 2021.7.0 yet still no HD Native available to select for output
I've just updated macOS to Monterey after being on Big Sur. The HD Driver doesn't seem to work at all. It doesn't show as an output device in macOS. I've uninstalled, reinstalled, restarted the computer, ran the touch command in Terminal and still no luck. Any idea how to get the HD Native/HD Omni to work as a sound output?
MacBook Pro Touch Bar (15-inch, 2016 2016), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3, Radeon Pro 460 4096 MB
Intel HD Graphics 530 1536 MB | macOS Monterey | Avid HD Native Thunderbolt | Avid HD Omni | Pro Tools Ultimate | Avid Artist Control | Avid Artist Mix
Avid Artist Transport | Genelec 8351b Monitors | Genelec 7360A Subwoofer x2 | Slate Digital VMS Virtual Microphone
Old 12-06-2021, 07:52 PM
Sardi Sardi is offline
Default Re: Updated to HD Driver 2021.7.0 yet still no HD Native available to select for outp
Mac OS Monterey is not supported.
Your best bet is to roll back to Big Sur. If you want to try your luck and persist with Monterey, try a reinstall of the HD driver.
https://avid.secure.force.com/pkb/ar...ation-on-macOS
Old 12-06-2021, 08:03 PM
off the wall's Avatar
off the wall off the wall is offline
That was a mistake. Monterey is not approved for Pro Tools and even those who have gotten it to work, many plug-ins crash Pro Tools on launch. Also you aren’t even using the latest driver.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 12-06-2021, 08:09 PM
I upgraded because it wasn’t working on Big Sur. The odd thing is that it used to work fine but suddenly wasn't working. On big Sur when I uninstalled and reinstalled, it would work after it's installed and asking you to restart to finish. If I don't restart then it works.
Old 12-06-2021, 08:10 PM
What is the latest driver and how do I get it? That's what was in my available downloads.
I updated to Monterey because the driver wasn't working on big Sur either.
Old 12-06-2021, 08:36 PM
_JJ_ _JJ_ is offline
Be sure that "prefs" >> "security and privacy" is not blocking the driver from being fully installed. Sometimes you need to go there to give the installer permission to finish the job.
Old 12-06-2021, 09:16 PM
Eric Lambert's Avatar
Which Driver installation file did you use, the separate download, or the one which is included in the ProTools installation itself? I had terrible trouble with the separate download and never got it to work whereas the one included with PT worked right away.
I don't know if that's your issue, but it was mine. Maybe Avid has fixed all the Driver installers by this point.
Old 12-07-2021, 02:43 PM
I used the one in the downloads section of my PT section at my.avid. So I supposed that's the separate download. If there is a newer driver than the one in my downloads, can I get a link or instructions on how to get it?
Old 12-07-2021, 02:53 PM
nothing out of place there.
Old 12-07-2021, 02:57 PM
What does that mean? Did you enable the driver there in the past? The option to do so disappears after 30 minutes so you won't see "nothing out of place there" unless you rerun the installer.
2021.6 Clips/Markers Grid Select Broken the.engineer Pro Tools 1 05-26-2022 02:26 PM
Updated to HD Driver 2021.7.0 yet still no HD Native available to select for output Focuret Pro Tools HDX & HD Native Systems (Mac) 0 12-06-2021 07:25 PM
PSA: PT 2021.7 & HD Native Driver & Big Sur & Izotope RX7 milosziv Pro Tools HDX & HD Native Systems (Mac) 6 08-25-2021 07:36 PM
updated to Pro Tools 2021 and now only have 24 bus sends instead of 32 justjohnmusic99 Pro Tools 3 06-22-2021 04:22 AM
2021 Scorch still being updated?? Carl393 Avid Scorch (iOS) Forum 6 04-29-2021 12:43 PM
