Old 06-06-2003, 02:04 PM
macs100 macs100 is offline
Default Importing audio from cd
I'd like to have all my audio tracks from my sample cd right there on my hard disk (it seems so slow taking them one by one from the cd), but when I drop the cd icon onto the 'HD' icon, only the "image" is copied.
Do I have to do it track by track?
Hope this makes sense,
Thanks,
Mac
Old 06-06-2003, 02:16 PM
MoreMeintheMonitors MoreMeintheMonitors is offline
Default Re: Importing audio from cd
You have to select the contents of the CD, then drag them to your HD. I'm assuming you're on OSX of course.
If you're still having problems - is this an audio cd or a data cd? What OS are you on?
Old 06-06-2003, 02:23 PM
Hi MoreMe...
I'm in OS9,
Any ideas?
Mac
Old 06-06-2003, 02:54 PM
Sam Amato Sam Amato is offline
Maybe you need to convert the files before importing them to Pro Tools. If you have Toast just drag the CD in and use the "extract" feature to do this.
Hope this helps.
Macbook 2GHz C2D, 2GB RAM, OS 10.4.8
M-Audio Profire Lightbridge
Pro Tools Academic 7.3.1cs1
Old 06-06-2003, 03:08 PM
TAPKAE TAPKAE is offline
You can import directly to PT by using the "Import Audio From Other Movie" option under the Movie menu. You have to jump a few hurdles, but it works.
OS 10.3.9
1.25 mhz single G4, 1.25GB RAM, Firewire & Internal recording drives, Nomad Factory plugins
PT 6.4, 001, Motormix
Old 06-07-2003, 11:07 AM
orage orage is offline
Hey macs100,
Since you're still in OS9, check out SoundApp. A great little freeware converter that'll handle almost any format you can through at it!
Aqui!
Paul Peterson
Sound Director
The Old Globe
San Diego, CA
Old 06-07-2003, 02:08 PM
CCash CCash is offline
I believe you just want to put the contents of an Audio CD on your hard drive, right? Yes, you'd think it would be simpler. If you have Toast, it comes with an extra utility called CD Audio Extractor. It works pretty well. But it's a one-at-a-time thing.
I installed iTunes the other day, and I'd bet this will let you copy an entire CD at once... just make sure it's not set to convert everything to MP3, which I think is the default. Pretty sure you can create .wav files.
Lastly, as someone else said, if you're working in ProTools you can go to Movie>Import Audio from Other Movie to convert the CD one track at a time. I like Toast's Extractor better.
Old 06-07-2003, 06:27 PM
Hi guys,
Thanks for all the great suggestions.
I shall play around with SoundApp and also check out iTunes more carefully - I just got it recently too and assumed it extracted one track at a time...
Sorry if it seems like a minor problem, but sometimes it's the little things that bug! : )
All the best,
Mac
Old 06-07-2003, 06:50 PM
Hi guys,
All the best,
Mac
Importing audio files for remix - convert or set session to match source audio? LSW Tips & Tricks 22 09-09-2014 09:28 PM
PT9 Crashing when importing audio from an audio CD Here and Now Stonehenge84 Windows 8 12-20-2012 03:26 PM
Importing DVD Audio/Mpeg audio DerekDigital Pro Tools TDM Systems (Mac) 3 06-07-2005 06:16 PM
Importing Audio From a DVD??? CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 09-09-2004 07:22 PM
Importing audio from a CD bounce88 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-09-2001 02:31 PM
