Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 09-17-2021, 05:06 PM
andre.st.denis andre.st.denis is offline
Default Re: Anyone running Carbon successfully on a Hackintosh?
Originally Posted by dominicperry View Post
So the original question was - what motherboard do you have that works?
I've also got the Gigabyte Z490 Vision D and the ethernet ports don't work for the Carbon. I can also confirm that a Ethernet -> TB2 adapter into a TB2 -> TB3 adapter does work. I tried a Ethernet -> TB3 (USB-C) and it doesn't work. I'm running a UAD Satellite between the two adapters btw and can turn the unit on/off without any issue, so it is possible to run a Carbon with a Hack. Has anyone had any luck installing a NIC that supports AVB though?
Old 09-17-2021, 10:53 PM
martthie_08 martthie_08 is offline
Originally Posted by andre.st.denis View Post
You can use Carbon with your normal Ethernet ports but it disconnects with the Sonnet Solo 10G PCIe card? I have the Gigabyte Z490 Vision D and I was thinking of getting that card but will probably hold off if that's the case. Did the Thunderbolt card work for you?
No, I can’t use Carbon with my motherboard‘s internal network adapter because it doesn’t support AVB.
The thunderbolt card did not work for me, you might have better luck though, it „almost“ worked..
I am looking to add the thunderbolt 3 card soon and will post the results here!
Old 09-23-2021, 09:13 AM
JTC111 JTC111 is offline
This article may be relevant to this discussion...
Hackintosh Studio Computers RIP - The End Is Nigh! https://www.pro-tools-expert.com/pro...ouAMqFJeKmJKKw
Old 11-22-2021, 04:34 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
If the past is any indicator, Apple will probably support Intel Macs 4 to 6 years after they stop selling Intel Mac Pros. I just Hackintoshed my z490 Vision D and I couldn't be happier. Very few issues or workarounds I'm dealing with (When I receive my Carbon that'll be one workaround). I'll be happy to use this rig till I can't update it anymore due to hardware limitations.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 11-22-2021, 07:25 PM
Philthy Philthy is offline
I'd love to hear how it works out! Timing to me looks like it would be easy to run a new ProTools Hackintosh rig for 5-7 years from now... plenty long for an update cycle. I will probably do that unless Apple really surprises with new machines, both on function and price.
Phil Mann
Silk City Music Factory - CT Recording Studio
  #16
Old 12-02-2021, 02:03 AM
Yamahaman Yamahaman is offline
Originally Posted by ilmalvaggio View Post
Runs smoothly here on Thunderbolt 3 with Apple USB-C to TB2 + TB2 to Ethernet Adapters.
Hi there, would you mind letting us know which TB3 card you are using to run Carbon? I've tried it with Sonnet Solo 10G but having the same issue with others and Carbon disappears after few mins. I'm running on Asus ROG STRIX Z390-F GAMING motherboard.
Thank you very much in advance
  #17
Old 12-02-2021, 09:52 AM
ilmalvaggio ilmalvaggio is offline
It's the Usb-C embedded in the motherboard (Gigabyte Z490 Vision D)
  #18
Old 12-02-2021, 11:05 PM
Oh I see. Thank you ilmalvaggio for your quick response!
  #19
Old 12-13-2021, 11:34 PM
abc1mce2's Avatar
Been running Carbon in my Hackintosh for a week now and it's a keeper. I can tell it's an upgrade over my HD I/O sound-wise and is so easy to use...it just works. From what I have seen in M1Pro and M1Max MacBook Pro's don't expect to pay anything less than $2600. This is the reason I decided to hack my z490 and be done with it. Before I pay an arm and leg for a new Mac Pro I'll hack the z690 mobo or whatever comes after that.
Bricasti M7 (2)
Lexicon PCM96
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
  #20
Old 12-14-2021, 12:24 AM
Quick update, after installing a Titan Ridge card in my z390 hackintosh the Carbon works flawlessly with it, had zero problems or connection issues.
Is anyone running Apollo with Thunderbolt on Hackintosh? Melodeath macOS 7 10-17-2017 09:09 PM
Who is Running PT 11 HD Native successfully K Roche Pro Tools HDX & HD Native Systems (Mac) 17 09-27-2013 12:02 PM
Is any one running i7 970 successfully with PT9? Violet Windows 2 05-11-2011 05:00 PM
Is anyone running 5.1 on OS8.6 successfully? marc@soundpost Tips & Tricks 7 06-26-2001 03:51 PM
