Old 05-18-2021, 11:43 AM
Russell W Russell W is offline
Default Playback engine in Pro Tools First
So I'm completely new to this. Was installing Pro Tools First via a tutorial and got to the playback engine configuration. As far as I understand, since I don't have any additional outputs or plug-ins, I should choose Built-In Output. The problem is, Built In Output is not in my drop down box. I chose MacBook Pro Speakers, as that seemed close enough. But when I open up a template and try to play the loops that come with them, I can't hear anything. I have chosen every other option from the Playback Engine drop down menu and still have the same problem. Am I doing something wrong? I'm on a MacBook Pro with a Catalina 10.15.7 OS
Old 05-18-2021, 03:48 PM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Playback engine in Pro Tools First
I’m guessing after choosing your onboard sound device as the playback device that you also set the default output to your speakers?
After that, all you should need to do is make sure the output of the track your loop is on is set to whatever the speakers show up as.
Will
System Details
Old 05-18-2021, 05:50 PM
Top Jimmy's Avatar
Pro Tools can be prickly about having only an output assigned. In AudioMidi setup, configure Pro Tools Aggregate to use the inputs and outputs on your MacBook. In Pro Tools, select Pro Tools Aggregate as your interface.
James Cadwallader
Old 05-19-2021, 03:52 AM
And don't forget to change security permissions in OSX to allow access to the microphone. https://support.apple.com/guide/mac-...hla1b1e1fe/mac
Jack
QAPLA!
S6L/S3L Pro Tools Playback Engine Restrictions BrockmSi VENUE Live Sound Systems 4 06-22-2020 04:56 AM
Pro Tools playback engine is being stubborn ashahay Windows 6 10-25-2017 09:02 AM
Playback Engine Issue (Won’t load session with chosen playback engine) MattyJones Pro Tools 11 0 11-02-2015 11:52 AM
Need Help with Pro Tools 9 Playback Engine for MAC James Trashy Pro Tools 9 2 09-30-2011 02:18 PM
Pro tools and Playback engine Help spidey01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-09-2009 10:15 AM
