Old 05-15-2021, 02:52 PM
LivingMeme LivingMeme is offline
Default What's the Transfer Record button appear like?
Please post image of "Transport Record button"? I keep on finding it mentioned in my "Intro to Pro Tools" .pdf manual. Thanks in advance for your help & patience.
Last edited by LivingMeme; 05-16-2021 at 03:11 AM. Reason: Input Transport to replace Transfer
Old 05-15-2021, 03:22 PM
_JJ_ _JJ_ is offline
Default Re: What's the Transfer Record button appear like?
Do you by chance mean the "transport record button"? That's just referring to the "transport" which is the floating window of main controls as seen below. This window can be placed anywhere you want it, even dragged to a 2nd screen for handy access. If you don't see it, look under the "Window" menu, scroll down, and select it.
Old 05-15-2021, 03:23 PM
ITs not really a function in either window(MIX or EDIT) but its a checkbox to tell PT how to address hard drives(it might be found on the Workspace page, but I'm not sure as I have not seen or used the workspace in a decade). "Record" means that you can record to that drive. "Transfer" means that the drive can only be used to transfer data to another session or system, but cannot be recorded to. Search the help files(aka the manual) for more details
Old 05-15-2021, 03:38 PM
JFreak's Avatar
JFreak JFreak is offline
Yes there are three kinds of drives; transfer, playback and record. You can change the settings in Workspace Window
Janne
Old 05-15-2021, 06:04 PM
OK, my lame answer forced me to go find what you knowledgable guys are talking about - which must be this popup menu in Workspace which gives you those drive options. Is that what the OP is searching for?
I sure learn a lot in here. Thanks.
Old 05-16-2021, 03:09 AM
Thanks again, JJ. All of you are correct in a way, but I was erroneously referring to the "Transport Record button" as JJ described and displayed (above).
Old 05-16-2021, 07:01 AM
As I re-read the original, I realized I may have been on the wrong path. It sounds like you are just starting out so there is a ton to learn. Your best approach is to hit youtube and type something like "getting started in Pro Tools"(without the "") and watch some tutorials. If you don't mind spending a little money(and it will be well-spent), groove3.com offers some of the best tutorials available
Record 1 audio track, then go to record a second, the timer button flashes... help tdubthatsme General Discussion 5 02-27-2011 04:39 PM
Greyed out record button - can't record on those tracks? Ty Ford 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-22-2008 02:43 PM
Master Record button doesn't record arm MIDI tracks? Borg ICON & C|24 1 10-29-2007 07:39 AM
No Record Enable Button Kwasi J 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-03-2006 12:50 PM
green record button toy box 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-30-2004 06:31 PM
