Old 07-01-2022, 08:32 AM
petreestow petreestow is offline
Default How to skip region cycle like you can in logic
Say I'm playing back a song with
V
C1
V2
C2
B
C3
Outro
and I want to playback and skip over chorus 3 (B to Outro) how would I do this?
Also, I want to do this without deleting anything from the timeline.
Thank you.
Old 07-01-2022, 01:30 PM
Default Re: How to skip region cycle like you can in logic
Unfortunately, Pro Tools doesn't allow this. Having said that, there are some ways around that problem and here is what I would do:
1-Open the session and go to File>Save Copy(check the box to include audio files).
2-Open the copy version. Enable the ALL group>highlight the part you want to skip>select Shuffle mode(F1)>delete the highlighted clips.
3-if you get what you want, great!(save this as your new version). If not, Ctrl-z is your best friend
since you are working on a copy of the original session, no matter how much you try to screw up, the original session remains untouched BTW, the same technique works for adding in, like if you decide you want to double-up the last chorus(ALL group enabled>highlight the chorus>select shuffle>Paste(or duplicate the clip(s). In all cases, remember to revert back to GRID or SLIP because Shuffle mode(if you forget its enabled) can wreak havoc(as can forgetting to disable the ALL group). In any case, Ctrl-z to the rescue
S1 Automation modes skip in Logic & ProTools QuacksMeUp Avid S1, S3, Dock and Control App 1 02-25-2020 08:16 PM
"Cycle Playlists" shortcut logic SigFriedChicken Pro Tools 2018 2 06-14-2018 02:46 PM
Cycle Skip Feature completeidiot23 Pro Tools 10 0 03-25-2012 07:16 AM
Logic Master Pro Tools Slave-MTC Cycle problem tran Pro Tools TDM Systems (Mac) 0 08-09-2006 05:21 AM
Region exchange - Logic and PT Update me Pro Tools TDM Systems (Mac) 2 01-03-2000 09:34 PM
