#101
Re: I Got Pro Tools 7.3 to recognize 2.7GB of memory- Here's how
No, but it should work the same. This program patches any .exe to 'large aware'.
#102
So i want to know if is it true :-( alex |
#103
Try it and see. Just make a back up of the .exe first. If it doesn't work, replace the .exe.
#104
I can't try because I have not m-powered.
I want to buy it only if this work. Can anyone tell if m-powered see more than 1.5GB of RAM ? Can Digidesign support answer at my tech requst ? alex |
#105
There may be one reason. It would put Mac and PC versions of LE on different footing, since Mac has no way to do a large access patch (AFAIK).
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
#106
Yes, M-Powered sees more than 1.5GB of RAM if you patch it properly.
#107
"It is called LaaTiDo utility!"
For what its worth, I installed this 3 days ago and my system has been running fine since (3 days of 6-8 hours and multiple sessions). Can't comment on a performance boost as I am not using lots of VI's. A couple of instances of ezdrummer and several instances of Drumagog.
#108
They already are on a different footing.....Leopard is 64 bit from top to bottom and PT runs on it now. This is despite the fact that 64 bit Windows was introduced 2-3 years earlier. As I understand it OSX's memory managent model (which is slightly different then Windows) works like this.... 2GB for OSX and 2GB for each individual application/plug in. Theres not any need or reason to patch PT on Leopard. Patching XP is only making up for the current lack of 64 bit Windows support. I suspect that its this very reason that Digi has let this thread live.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#109
Oh, good! I was already looking forward to the upgrade to Leopard and PTLE 8, but now I'm ecstatic! Until next year, I'll still be on a G5 with 10.4.9 and LE 7.3.
#110
Here's a url http://www.anandtech.com/gadgets/sho...spx?i=3034&p=3 that explains this 3G switch and why Windows 32 bit is inherently set at a 2G per application/2G for other system uses limit. This link was actually early in this thread, but thought I'd bring it up again.
Read the entire article. It's about game usage and what happens to Windows systems when it becomes memory intensive. The article will give you good insight as to what this is all about. So this patch in this thread is setting the application limit at 3G. This leaves 1G for other system uses. Some of the earlier comments were that graphics suffered, or there were BSOD, etc. Understandably. But if you're experiencing problems with 3G, why not try and set it to, say, 2.5G instead? That'll leave the system with 1.5G, etc. Steve
Worship Leader * Producer * Guitar Man Intel i7 3930k CPU, Gigabyte GA-X79-UD3 MB, G.Skill 16GB (DDR3 1600) RAM, WD Caviar Black 750GB HD x4 Neve 5043 Comp * Manley Dual Mic Pre * Apogee Rosetta 200 Eleven Rack (live rig and studio rig!!) Win7 * 003R * PT 11
Pro tools 8 doesn't recognize 192 i/o | supafuzz | macOS | 8 | 01-14-2014 08:12 AM |
Pro Tools HD 9 Doesn't Recognize 2nd 192 io | oechols | Pro Tools 9 | 2 | 05-09-2011 06:18 AM |
Pro Tools can't recognize 192 I/O | Juraj Bernáth | Pro Tools TDM Systems (Mac) | 5 | 11-03-2010 08:46 AM |
Pro Tools LE does not recognize more than 1 CPU | done_411 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-22-2010 06:32 AM |
Pro Tools Does Not Recognize M Box | beelofi | Pro Tools M-Powered (Win) | 3 | 01-15-2007 10:21 AM |
