Old 12-03-2021, 09:57 AM
c-post c-post is offline
Default largest IDE drive for protools 6 data?
When I had my TDM system restored last year, my G4 seemed unable to read large harddrives in the 200 gig range (for sound file use). Protools seemed unable to recognize the drives. Is there a drive size limit for these machines?
thx
J
"TISH! You spoke PROTOOLS! Speak some more protools, Tish... disk allocation, degree of thinning, timeline insertion...ANYTHING!"
Old 12-03-2021, 09:58 AM
Default Re: largest IDE drive for protools 6 data?
Partition size limit depends on your OS, so share that first. As far as PT is concerned, it recognizes as big files as WAV specification allows.
Old 12-06-2021, 08:22 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
thx
J
Iirc, the G4’s can’t see a drive bigger than 127GB, or somewhere around there. I believe you can use a bigger drive but it is only possible if you format it as a 127gb drive from the G4. The additional space on the drive would not be usable in this scenario.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 12-14-2021, 10:11 AM
groovebrother groovebrother is offline
Hello i have just checked with Tiger & Leopard : no problems to real & write 500Go & 1To SSD's as well as 500 Go IDE
See my signature for specs
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8
Old 12-14-2021, 10:15 AM
Yes, but the problem is there was paid upgrade to 6.4 HD (delay compensation) and if you did not do it you are limited to Jaguar. Later PT6 versions however work on Panther (6.4 and later) and Tiger (6.9 and later), but even then, as John said, you are limited to what the hardware allows.
Old 01-01-2022, 02:39 PM
THANKS TO ALL! Very useful information!
yours
JCG
Data restoring from a formatted drive RAID-0 Drive antonis Post - Surround - Video 10 06-25-2018 05:02 PM
m.2 PCIe SSD: better off as system drive or data drive? dvdr Pro Tools 12 4 01-12-2018 10:22 AM
Largest startup main drive recommendations RuffinMedia macOS 4 02-06-2012 08:57 AM
What's the largest drive i can put inside my G5? WildHoney Pro Tools TDM Systems (Mac) 2 11-17-2006 07:54 AM
largest firewire drive? gregfrey Pro Tools TDM Systems (Mac) 9 11-14-2003 04:09 PM
