Old 05-19-2021, 04:25 AM
marsian marsian is offline
Default Re: S1/DOCK/Control loose connection every now and then...
Hi Eddie,
I'm a bit lost. It's not getting better.
I ordered another WiFi Router, maybe that helps.
Best
Maik
PT HDN 2024.3, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.4, BM Decklink Extreme 3D
mars13.de
Old 05-20-2021, 07:17 AM
EddieJones's Avatar
Please report back once you have the new router installed.
Old 05-26-2021, 03:50 AM
Hi Eddie,
I tried another router, but the LAN connection is still unstable. It seems, that WiFi connction is much more stable.
Can you suggest an USB-LAN adapter that is reliable?
Thanks.
Best
Maik
mars13.de
Old 05-26-2021, 08:36 AM
EddieJones's Avatar
Whats wrong with using Wifi?
Old 05-27-2021, 04:09 AM
Hi Eddie,
there is nothing wrong with wifi in general.
But I would have liked to use a lan connection and reduce the number of wifis in our studio.
I thought, that a lan connection would be much more stable, but the opposite seems to be the case.
Best
Maik
mars13.de
  #16
Old 05-27-2021, 06:57 AM
EddieJones's Avatar
It should be better yes!
  #17
Old 06-09-2021, 10:14 AM
Just a short update...
Got a new, very fast wifi-router. Control (iPad Air2) ist connected via 5G wifi.
It runs stable for most of the time, but occasionally short interruptions happen.
Then all eucon units are disordered for a short time and are loosing their fixed fader setup.
That's not really satisfying in the middle of a mix/recording.
Best
Maik
mars13.de
  #18
Old 06-09-2021, 10:35 AM
EddieJones's Avatar
Best
Maik
Did you check all the settings and things listed on this help page? https://avid.secure.force.com/pkb/ar...ontrol-Support
This is not normal for the Tablet to disconnect. If any surfaces disconnect then yes EuControl has to reconfigure itself.
  #19
Old 06-14-2021, 01:59 AM
Hi Eddie,
I double checked all settings. Everything looked good.
After some time of observation, I discovered that not the iPad seems to be the problem, but the two S1 and the dock are disconnecting for a short time.
I have no idea what causes this.
Best
Maik
mars13.de
  #20
Old 06-14-2021, 10:38 AM
EddieJones's Avatar
Are you sure. If you run without the tablet on, does it still happen?
Recommended ethernet switch for Artist and Dock Connection sjgam Artist Series 5 10-19-2018 09:09 AM
Control App with Dock Connection Question sjgam Avid S1, S3, Dock and Control App 1 10-19-2018 08:12 AM
Some Faders or Buttons Randomly Loose Connection Barry Johns ProControl, Control|24, Command|8 1 06-14-2014 01:40 PM
MBOX 2 USB connection Loose! help mfaktr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-06-2008 12:04 PM
Orig MBox Loose USB Connection. Any Suggestions? Matt Foglia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-22-2007 12:00 PM
