Old 02-27-2020, 11:35 AM
hugoleitao hugoleitao is offline
Default S3 Oled/fader replacement?
5 of my S3 Oled displays are now barely visible and becoming useless after 3 years of regular use. I also have two fader cracking constantly and failing to write automation properly, already tried proper fader lube but it didn't help much.
Does anyone had fader's and Oled's replaced after warranty expired? What is the right procedure in Europe? Should I send my unit back to my reseller or should I replace those parts myself?
Old 02-27-2020, 12:44 PM
reichman's Avatar
reichman reichman is offline
Default Re: S3 Oled/fader replacement?
The faders are easy and cheap to replace. Avid will sell you the faders and give you a doc with three pictures. You unscrew the hex screws above and below the offending faders, flip the S3 over on a soft surface and take off the back panel. Each fader comes out with one PCB connection. 5-10 minutes of work. I think the faders are available direct from a parts company as well.
With the OLEDs, I don't know.
Good luck!
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 02-27-2020, 02:24 PM
Good luck!
Great! I thought something more complicated. Hope someone chime in regarding the Oled's.
Old 06-07-2021, 07:28 AM
_charlie_ _charlie_ is offline
I just responded to your PM at GS, but for the benefit of everyone, here's another thread with others' experiences with the OLEDs: http://duc.avid.com/showthread.php?t=396234
I'm glad to hear the faders are replaceable!
Old 06-09-2021, 09:28 AM
EddieJones's Avatar
You could also take out a support contract 0541-60111-15 Avid Advantage, S3 Extended Hardware Coverage Renewal $249. Wait 45 Days and then get it all fixed with an Advanced replacement.
Command8 fader replacement mparkinson ProControl, Control|24, Command|8 5 02-14-2020 04:52 PM
S6 fader replacement leopod Avid S4/S6 1 06-27-2018 06:47 PM
OLED Channel Name / Fader Value preference teedeecee Avid S1, S3, Dock and Control App 8 04-15-2018 11:32 AM
Replacement fader stainless ICON & C|24 2 01-13-2010 04:42 AM
Help with fader replacement Ayrik ProControl, Control|24, Command|8 2 01-08-2004 09:55 AM
