Re: Pro Tools HD 7.2.1 for Mac Pro
Same as syspilot ..... but our sys/prefs work fine as well as sys/profiler works fine too.
We just got a brand new unopened version of HD2Accel PCIe and MacPro. Machine Name: Mac Pro Machine Model: MacPro1,1 Processor Name: Dual-Core Intel Xeon Processor Speed: 2.66 GHz Number Of Processors: 2 Total Number Of Cores: 4 L2 Cache (per processor): 4 MB Memory: 1 GB Bus Speed: 1.33 GHz Boot ROM Version: MP11.005C.B00 SMC Version: 1.7f6 Serial Number: YM6334K3UQ2 Installed Core in slot 2 Process in slot3 no card in 4 Core ribbon connector thingy from B to A on Process Added a new additional harddrive and ran a fresh install of 10.4.7 wih no "extras" onto this disk. Installed pace iLok drivers Reboot Installed pthd721_30980.dmg Reboot Repaired permissions. Reboot Run Protools and we got the same errors as syspilot >> DAE error -4 followed by general error -9003 . Reboot Repaired permissions. Shutdown Removed HD Accel process card. Reboot. Ran Digitest application and it shows our HD core. When we runs the test it crash-quits right away. Repaired permissions. Reboot Same as above ... etc. Help digi.
MacPro 5,1 - 2 x 2.66 6 core - 32G Ram - SSD's - Mac OSX 10.12.6 - HD Native Card - Omni - Focusrite RedNet 5 - Avid Dock - iPad2 |
Hello,
Digi, will there be support for the Magma 6 Slot PCI Express to PCI-X Expansion chassis with the Mac Pro? I just bought a new MacPro dual core 2.66 computer installed PT 7.2.1 and connected my Magma chassis and nothing. I know this is unsupported at the moment but I was hoping it would work but it doesn't. Protools crashes at the initalizing hardware portion of the startup. Will there be support for the Magma stuff? Thanks, aar |
Hi there!
Does 7.2.1 run os OS 10.4.8? Because we updated the firmware on the Mac Pro and now OS 10.4.7 is a drag! Apple says, that you can't downgrade the firmware... Can we install 10.4.8? Please say yes... |
Thanks, Pete |
Because I've already got a Magma chassis on my G5 and I was interested in the new PCIe->PCI-X bridge card they do, which is essentially what these new chassis have inside. I may end up having to buy the Expansion HD, I'm aware of that. Thanks, Pete |
hi arr if your running a quad intel pro 2.66 then its an upgrade to 7.2.1 protools
hi victor 0 yes 10.4.8 works perfectly with 7.2.1 pt go ahead running that system myself
Hi there,
did you get your Dae error -4 issue solved? I´m having the same liturgy right now on my brand new MP 2,66 / HD|3 -combo... -rake- |
