Old 07-17-2007, 07:47 PM
ericcodeseven ericcodeseven is offline
Default problems with my control 24 power supply?
i have had alot of problems with my 24 lately. first off all the light on the board will randomly come on and then stay on sometimes. i read that this was a common problem and it can be fixed by reconecting the power supply. so what i did was pull the power filter in the back out and unpluged the brown, green and blue wires, reconected them and the i had no problems, until today. the problem returned and then i went through the same steps and once i pluged in my power supply from the outlet, it blew a fuse in my house. after that. the 24 will not work. i need to know if it is as simple as replacing the emi filter or what. i contacted digidesign today and they told me i would have to take it to another state 5 hours away from me to the closed digi ddesign authorized repairman and it would cost me about a 1000 bucks just to have it serviced. i am broke and cannot afford this. i really need help here. does anyone out there know what i can do to fix my problem?
Old 07-20-2007, 09:39 PM
Scott Goldberg Scott Goldberg is offline
Default Re: problems with my control 24 power supply?
Hi Eric,
Welcome to the DUC. If you can give us more information about the C24 and how you've got it plugged into your power, that will help. Is it an older C24? The old ones had power supply problems and you may be experiencing an intermittent problem. Hard to say without knowing if yours is new or used and, of so, how old. The older ones had many troubles with their power supplies. Good luck and try to let us know these things if you know them.
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Hi Eric,
Welcome to the DUC. If you can give us more information about the C24 and how you've got it plugged into your power, that will help. Is it an older C24? The old ones had power supply problems and you may be experiencing an intermittent problem. Hard to say without knowing if yours is new or used and, of so, how old. The older ones had many troubles with their power supplies. Good luck and try to let us know these things if you're able.
Scott Goldberg
Gold Recordings
Control 24 Power Supply Self Repair jschival67 ICON & C|24 9 05-06-2022 02:39 AM
Control 24 with no power supply - to fix or not to fix the blast ICON & C|24 1 12-24-2011 03:54 PM
Control 24 Power Supply Failure bigstribs ICON & C|24 1 06-23-2010 11:56 AM
Control 24 Power Supply Problems jaco69 ICON & C|24 3 10-23-2007 10:01 AM
Control 24 Power Supply Issue digi2000 ICON & C|24 1 06-05-2004 07:11 PM
