  #21
Old 12-01-2021, 06:08 AM
Default Re: Freeze vs Commit
Originally Posted by Extreme Mixing View Post
I also usually commit Melodyne when I'm done tuning because I love the Clip Gain line for automation.
Steve
Ha. I've found myself doing a lot of that within the Melodyne environment of late.
  #22
Old 12-01-2021, 12:35 PM
Mixmaster Rick Mixmaster Rick is offline
For me the CPU hit is minimal; it's more about how to retain as much memory as possible.
  #23
Old 12-01-2021, 12:52 PM
JFreak JFreak is online now
Originally Posted by Mixmaster Rick View Post
Yes, freezing/commiting also frees up memory (after session restart).
  #24
Old 12-01-2021, 01:15 PM
I use Freeze as a strictly temporary thing and unfreeze when the session is ready to close. I can always re-freeze the next time, or I will COMMIT, and leave the original track inactive but showing if I think I will need to make changes. With Melodyne, I will select "Do Nothing" to the original track and move the .cm audio file back to the original track on a new Playlist and make Melodyne inactive(or remove it). You have many options, so find what suits you best
  #25
Old 12-01-2021, 04:14 PM
take77 take77 is offline
Thanks Steve, for reminding me of the commit up to insert feature.
I'll have to read up since I'm just getting back into everything.
A rough sea makes a smooth sailor.
Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD
Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6
Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory
  #26
Old 12-02-2021, 11:11 AM
Extreme Mixing Extreme Mixing is offline
Yes. I've done it both ways. Clip Gain is just more normal to my habits. There is nothing worse than adjusting some clips only to realize that nothing is changing because PT is not really playing back the pretty pictures that you are looking at! But it all works. Timing changes are usually best done in Melodyne. For me...
Steve
Steve Shepherd
Extreme Mixing
  #27
Old 12-02-2021, 01:11 PM
Steve
Ha yeah! The number of times I go to a mute a clip and then... d'oh!
  #28
Old 12-03-2021, 06:00 AM
When using Freeze or Commit what is the impact if I use any Automation on the track?
  #29
Old 12-03-2021, 06:24 AM
Sardi Sardi is offline
Automation will be visible on the frozen track as its just rendering the audio in place.
Commit will print the automation onto the newly rendered file if you tick the boxes. Otherwise you can choose to not have the volume, pans, mutes etc. printed.
Have you tried either? A dialog box will pop up when you go to commit and you can see all this stuff pretty clearly.
  #30
Old 12-03-2021, 06:41 AM
Thanks! I haven't tried either yet as I am in the middle of a project but I expect I'll try both out very soon.
Commit / Freeze / Rendering Tracks causing Pro Tools to freeze or crash iamkimosabi Pro Tools 2020 11 09-02-2023 09:09 AM
Commit/Freeze or something else? joeydego Pro Tools 2018 4 09-03-2018 02:24 PM
Vacuum VI won't Freeze or Commit? Bushpig Pro Tools 12 8 12-24-2016 11:52 PM
Commit and Freeze both cause 100% CPU usage Steevp Pro Tools 12 2 05-20-2016 12:07 AM
Track commit/freeze Thenewexhibit Pro Tools 12 2 12-23-2015 02:50 PM
