TL Native Space IR's
Is there a special trick to installing downloaded IR's to the Native Space reverb?
I've followed the instructions and tried installing unzipped IR's...but they never show up in the list in the righthand pane. Should I uninstall the plug-in. Download again and reinstall? |
Re: TL Native Space IR's
Please do a search, Myself and several others have been bitching about this for years.
www.rickqueststudio.com |
If these are the IRs that come with TL Space, you have to unzip the .tls files, and then you install each one individually through the menu in TL Space.
In TL Space, open the IR browser and pull down the edit menu. You should find a command to Install TL Space IR Package. Use this for each of the .tls files that you want to install.
Did you install them from inside the plug in window itself. I had no problem with all the TL space IR's or with ReCabinet.
Also, if you are using 8.0.4 and win7 64, they probably won't show up even if you do install them correctly. A few folks have had a problem with this. There's a work-around, but it's silly to have to do that in my humble opinion..
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
I did do the install that TopJimmy posted. I get as far as the install window..that's where I fail. No error messages. Nothing ever shows up in the browser pane...even when I refresh.
I'm using 8.0.3 and Win 7 32 bit. My downloaded/unzipped IR's are in a folder on my D drive. My audio/sessions are on a removeable drive. I can post a Sandra report if needed. Didn't think this was that sort of issue though. There was a mention of a workaround. I'd love to know what that is. I did search prior to posting. Everything I found applied to earlier versions of PT. Last edited by Chuck1073; 08-20-2010 at 07:30 PM. Reason: left out 32 bit |
Mine all loaded fine under Win7 64 bit. They don't spill out the same way under the list, but they are all there and load/work fine.
Got it! Un-installed TL Space native. Re-downloaded the installer and re-installed.
Works like a charm! Thanks everyone. |
Good detective work
TL Space IR's | Roland Clarke | VENUE Live Sound Systems | 0 | 10-15-2010 12:54 PM |
TL Space IR's Question | WernerF | Pro Tools TDM Systems (Mac) | 14 | 11-16-2009 04:59 PM |
Tl space ir's and pt8,cannot install | Maddawg383 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 09-01-2009 03:14 PM |
IR's for TL SPACE | Hearfilm | Post - Surround - Video | 4 | 04-11-2008 09:34 AM |
TL Space IR's don't map to automation? | dBgogogo | Pro Tools TDM Systems (Mac) | 0 | 11-09-2006 07:17 PM |
