audio device underflow(-6085) during Playback
Hello. Playback produces "The audio device underflowed. If this occurs
frequently, try decreasing the "H/W Buffer Size" in the Playback Engine panel or remove other devices from the adio firewire bus. (-6085)" my system specs are: MacBook 2.0 GHz Intel Core 2 Duo (T7200) (MB061LL/A, white) upgraded to 2GB of RAM and 7200 rpm hardrive Mbox 2 Pro OS X 10.4.9 Pro Tools LE 7.3 H/W Buffer size is at 64 samples RTAS Processor 1 Processor CPU Usage Limit 70% Troubleshooting already attempted: Mbox 2 Pro is the only device connected to my single Firewire 400 bus. Zapped the PRAM. Downloaded the tech support folder: http://www.digidesign.com/index.cfm?...4&itemid=25974 Ran support utility and used it to delete preferences and databases. Used the Apple disk utility to repair disk permissions. Wireless networking and bluetooth are turned off. Reviewed Troubleshooting Pro Tools 6 & 7 on Mac OS X: http://duc.digidesign.com/showflat.p...&Number=177661 Please help.
Digidesign Mbox 2 Pro PT LE 7.3.1 Macbook 2 GHz Intel Core 2 Duo Version 10.4.9 4 GB memory(3.3 recognized) GLYPH-250 GB external hard drive |
Re: audio device underflow(-6085) during Playback
Just fixed this on a friend's system a few days ago. You said that you're running LE 7.3. Download the LE 7.3.1 cs6. This fixed it for him.
Here's the link for the Mac download. http://www.digidesign.com/index.cfm?...4&itemid=29369 Tom |
Thanks for the response Tom. Sounds like a simple solution. I like simple. Update forthcoming.
Pro Tools LE 7.3.1cs6 Update for Mac OS X did not clear up my particular problem. Any advice to fix my current situation is much appreciated.
You have posted in the TDM forum! most of the users here no nothing about setting up LE systems, you should post in the LE forum!! go to the forum home and scroll down to the MAC LE forum where you will find lots of LE experts Chris
Audio buffer underflow -6085 error on mac pro | paul mccarthy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 30 | 02-21-2011 10:25 AM |
buffer underflow -6085 firewire device, but i have mbox 2 usb? | nicnac712 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 08-03-2010 05:08 AM |
Unibody MacBook Pro vs. MBox 2 Pro (how I beat Audio buffer underflow -6085) | Arthur Nascimento | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-25-2009 09:40 PM |
audio device underflow(-6085) during Playback | M577 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 12-01-2008 07:16 AM |
audio device buffer underflow error please help | idleave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-05-2007 07:51 AM |
