Old 07-06-2014, 10:38 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Consolidation problem
I would try a Save Copy In, making sure a) you check copy all audio and b) that the folder/file is saved to a hard drive that is R in the workspace. This should put any audio files that are scattered all in one place. Then open the new session and try to consolidate the tracks.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-06-2014, 03:09 PM
priorytools priorytools is offline
Default Consolidation problem
Paybreaker… try checking : set up, disk allocation. It sounds to me like your tracks are assigned to different places. … short cut in the disk al' window, alt Click on a track ( this'll select all the tracks), then select folder from the drop down & nav' to your session folder. … now try your CDT.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Last edited by priorytools; 07-06-2014 at 03:10 PM. Reason: correction & addition.
Old 07-09-2014, 05:30 PM
paybreaker paybreaker is offline
I'm gonna look if the tracks are assigned to different folders when I get back home. I'm Away this week. Spontaneously it feels lile they should just consolidate to their assigned folders (there are only two different folders that I use) as each track only have audio files from one of these folders which should also be the folder where the track specific data is located. Otherwise that thing about bussing it and recording it on new tracks seemed like a smart and easy solution if it won't work I think I have room for that or otherwise at least for doing that with half of them at a time.
Thanks
Old 06-27-2022, 04:30 PM
lapieuvre lapieuvre is offline
Priorytools, thanks a lot ! Found this thread and fixed this problem.
Huge time saver
__________________________
MBP 2015, 2.8 GHz Intel Core i7, OSX 10.10.5, 16 gigs Ram,
PT 11.1.2 Clip consolidation & Fades dialog Problem brroberts macOS 1 05-05-2014 07:37 PM
Consolidation problem with 10.3.1 electroteque macOS 2 11-28-2012 12:07 AM
Elastic Audio consolidation problem regrexion Pro Tools M-Powered (Mac) 16 08-31-2010 05:40 PM
Consolidation? Rome630 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-18-2006 05:26 PM
consolidation ? jata Pro Tools TDM Systems (Mac) 6 10-16-2005 11:24 AM
