File numbering in template session
For some reason, when I start a session using Stationery Pad template session, my audio files start numbering at _08. I tried trashing the WaveCache file, but that didn't change anything.
I would like my files to start at _01. Thanks for your help. |
Re: File numbering in template session
Try creating a new session, then use import session data from your template. then i would use save as template and use pro tools templates instead of stationary pad. or if you must use stationary pad try saving the new session as one. Chris
Thanks Chris, those are good ideas. I'll probably start using Pro Tools templates; I'm just very old school and never got around to trying those out.
Importing a mix session template into a record edit session | bryced87 | macOS | 1 | 04-27-2012 04:24 AM |
File association issue when starting session from template | admix | Post - Surround - Video | 5 | 06-23-2009 06:54 AM |
Craeting an I/O Template or File | digimike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-19-2006 11:37 PM |
Template File Storage | ronstephens | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-17-2005 08:32 PM |
5.1 region list file numbering problem | scottgreiner | Pro Tools TDM Systems (Mac) | 0 | 05-01-2001 10:48 AM |
