ilok
Do i have to have my ilok connected to my computer always in order to use virtual instruments?
MacBook Pro core i5 2,53 GHz Mac OS X 10.6.3, 4Gb RAM. Digi 003 Rack+ |
Re: ilok
If the authorizations for those plugins are on the iLok, Yes.
Re: ilok
Most plugins (not sure about VIs) seem only to check the iLok when you launch PT. Some check when they are instantiated on a track (I think Revibe does this). But once PT is booted, if all your plugins happen to be the type that only check on launching PT, you can safely remove the iLok.
I'm not sure about VIs, which category they fall into, but easy enough to try, once PT is up and running, just take out your iLok and see what happens, worse thing is you'll get a message to put it back in I would guess. |
Re: ilok
No you don't I tested this some weeks ago, once the plugins are launched you can unplug your Ilok - it's a passive not active system. However you must plug it on every time you insert an Ilok enabled plugin.
I work with amazing people who do incredible things. Founder of the Expert Sites. |
Re: ilok
But what if you dont have an ilok yet, and you start authorizing plug-ins on your pro tools LE 003 for example, without an ilok usb key...will you be able to put those programs on the ilok later if you wish? |
Re: ilok
If the plugin vendor supports iLok as well as 'serial number' or 'challenge/response' authorization then usually you can change your method to iLok. For instance, Audio Ease Speakerphone, and Izptope RX support several methods. If you choose iLok, you typically won't be able to authorize with any other methods.
But not even VI or plugin supports iLok. Kontakt for instance is only a challenge/repsonse authorization, so even if you're using iLok for some things, that can't use it. |
ilok issues - ProTools 9 crossgrade LE (Please install the iLok Client Software) | pauledwards | Windows | 3 | 09-10-2013 04:02 PM |
Plugin auth weirdness - guest iLok prevents internal iLok? | Scott Helmke | VENUE Live Sound Systems | 3 | 09-07-2011 07:06 AM |
error: missing ilok authorization for pro tools 9. please insert the necessary ilok.. | weakluv | Windows | 2 | 07-07-2011 05:47 PM |
Can You Transfer iLok Licenses To A New iLok If Your Old iLok Is Broken? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-07-2009 03:51 AM |
Transfer iLok auth. from old iLok to new 003 factory iLok? | lamp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-20-2007 07:05 PM |
