Old 05-24-2021, 10:03 PM
Default Big Sur 11.4
Big Sur: MacOS 11.4 just released today. I upgraded one my test machine, ran a couple Protools 2021.3.1 test (large track count session, several plugins, virtual instruments). Everything seems to work as before, so I upgraded my primary machine to MacOS 11.4 too.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 05-27-2021, 12:34 AM
Becharax's Avatar
Becharax Becharax is offline
Default Re: Big Sur 11.4
Can you update us on the graphical glitches if they are still there ?
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
Old 05-27-2021, 09:59 AM
I haven't seen them because I normally just use the built-in screen on my 15" MacBook Pro nowadays. If I understand correctly, the graphic glitches happen on external monitors (especially higher resolution settings). I did not see the glitches in previous OSs or Protools versions, so I'll probably not see them in this OS update. I was using classic color mode previously. I recently switched back to "dark mode" to try to get used to it, so If I see any glitches, it might be related to that.
Obsidian Dragon
Old 05-27-2021, 11:13 PM
Becharax's Avatar
I have seen plenty on an iMac Pro ... Can't wait to update and see if we got rid of them finally
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 05-29-2021, 12:55 AM
Becharax's Avatar
Unfortunately the glitches are still there .... It's a Pro Tools thing after all ... eventhough the workflow is seamless ... those glitches are a pain in the ... shoulder
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 07-08-2021, 05:49 PM
mixedbymatty mixedbymatty is offline
Yah. I've been getting the glitches as well. pain in the shoulder for sure. lol
Old 07-08-2021, 10:30 PM
From what I'm reading in these threads, the screen glitches seem to be more prevalent in Protools 2021.6 than 2021.3.1. And those on an M1 based Mac are having beachballs and lagging UI performance.
I'm on a 2017 15" MacBook Pro (Intel i7) with 16GB RAM using the built-in screen with Protools 2021.6 and I don't see any glitches. I occasionally connect to a 4K monitor (mirrored instead of extended screen) and have not seen any glitches but I'm not on that screen much.
Obsidian Dragon
Old 07-24-2021, 07:22 AM
septemberlaine septemberlaine is offline
Glitches here too.
I'm also have a cpu usage issue all of a sudden.
Using for about a year without issue and now I can't get through a session. I'm assuming it's Big Sur because thats only change...
anyone else having a similar problem?
