I have two Envision 17" LCD Displays and I recently picked up a Beklin 6' VGA extension cable.. the results are disgusting. Can anyone recommend a high quality VGA extension cable that works well at high resolutions with LCD displays (analog)? All I need is 6'. Thanks.
-Dave |
www.networktechinc.com
They have great stuff. Got a 35-foot VGA with maybe...6% loss. They also have active USB extenders that work. |
Hi DDhung,
I don't Know what promblems you are having, but i had problems with a Nec 1700+ LCD Monitor, after installing a High Quality 6' Extension Cable my CPU/Monitor would (90% on the time) boot in 640x480 resolution, and without the abilty of chaging it in the Control Panel (Monitor) Secion. I would have to boot up 5 or 6 times before it came up on the higher res. after months of playing with it, i took the 6' ext cable cut it in half and soldered a new end, Now it comes up in the high res but it still does't reconize my NEC 1700+.. so that was my only solution, at least now i dont have to waste time reboot and crossing my fingers... i hope this helps ... Adam StudioOne Recording |
Thanks for the quick replies guys! I went ahead and ordered an extension from networktechinc.com. Hopefully it will work out for me. Thanks again.
-Dave |
Update:
Just recieved my extension cable from NTI.. it works great. NTI has a very extensive catalog of high quality cables, adapters and hubs.. definitely worth checking out if you need anything like that. -Dave |
Done with mix, Bouce with high quality QT | mikevarela | Post - Surround - Video | 5 | 04-21-2008 04:12 PM |
High Quality Pre Amp for 002 rack? | Mason00 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-31-2005 09:59 AM |
High quality D-SUB connectors. Which one? | Impala | ICON & C|24 | 9 | 02-19-2003 05:01 AM |
high quality clocks | gregfrey | Pro Tools TDM Systems (Mac) | 2 | 01-25-2003 01:03 AM |
High quality recordings? | del cosmos | Tips & Tricks | 4 | 02-16-2000 05:41 AM |
